Washed my Silver car, cleaned inside and out and everywhere in between.
Changed my toll tag from black to silver car :)
fucccckkkkkk, ripped my front bar off on my drive way, guess I will be fibreglassing tomorrow.
custommodz
Post by custommodz »
Front bar off for CAI tomorrow.
Replace busted sway bar with new one from D + poly bushes.
Pray that new king springs (brand new from ebay in orignal box only $70) and kyb shocks ($450 from rpw) have arrived. Replace all of those.
brad_gpx
Post by brad_gpx »
washed and polished my car and cleaned out the interior
the interior was so messy it could barely fit one person in
I8A4RE wrote:fucccckkkkkk, ripped my front bar off on my drive way, guess I will be fibreglassing tomorrow.
Nooooo I'm so scared of doing it too, so have raised mine a little bit more than needed just incase but still scrap :x
Yeah I have had to make ramps because were the start of the drive meets the road, there is a ditch. Someone stole one of me ramps the other day so I had to use my old. As I was crossing it (which I have to do in reverse) I must not have been on centre and slipped off the side. The ramp slammed up and broke the passanger side mounting point.
Oh no not good at all.
Yeah my driveway is ok but so embarrasing when I go to exit on to a road somewhere and i hear the scrap and know its not going to go out without doing some damage then having to turn around and reverse out 8O
The looks I get and not too mention the occasional pissed off other car near me :evil:
So umm... simon ay.... how good are you at fibreglassing :lol:
-Nighthawk-
Post by -Nighthawk- »
I want to attempt to redo my tappets tomorrow, but I don't trust myself :P
-Nighthawk- wrote:I want to attempt to redo my tappets tomorrow, but I don't trust myself :P
This is how i feel with everything on my car.
custommodz
Its fairly easy, just use another screwdriver to plug the deep gaps near the tappet you removed to save from 40 minutes fishing them out. :D
Tippin
Post by Tippin »
haha so did i, except it wasn't my driveway. Its all cracked along one side where ive moulded the DC lip to the stock bar
bugger :cry:
zuihoujueding
Post by zuihoujueding »
my mechanic did
1) VRS kit service
2) machine the heads and dip in acid bath
3) clean out all sludge, The amount of sludge at the cam area is unbelievable!
4) replace 8.5mm magnecor ignition coils
5) replace NGK iridium IX sparkies
6) Changed Nulon gearbox oil, added Nulon G70
7) Flush with Liquimoly Engine detox and change to Valvoline engine armour 10W-40 engine oil
8) change coolant.
9) replace alternator pulley and crank pulley with aluminum ones.
10) clean and seal reseal oil sump.
11) replace head bolts and some seals which are not included in the VRS kit
The mechanic found out that my timing belt is actually miss aligned by one tooth.
Results: Now the car sounds totally different. so much eager and louder than ever. Noticably feels more responsive and will update if the fuel consumtion have imrpoved.
Gholdwayne
Post by Gholdwayne »
new rear tyres from taleb tyres for my 17x8s. 205/45 falkens for 120 a tyre fitted.
also slightly guttered my passenger side rear rim so now i have to do some rim repair. damnit
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Had my front tyres replaced yesterday, cheap Marshalls. Tyre shop was clearly owned by Outlaw members. Skull memorobillia everywhere, skull and fire tattoos on the owner's arms, and a big f**k off dog behind the counter 8O
AJ
Post by AJ »
Devo! Hope it works out ok for you.
brad_gpx
Post by brad_gpx »
I feel like this now. Just make sure you put it back together perfect lol.
Gholdwayne
:lol: lolz, this is a day overdue, but rolled the rear guards with the help of olly... did one each :lol:
97 GPX Icelle Blue
FTO[For The Orgasm]
Gholdwayne wrote::lol: lolz, this is a day overdue, but rolled the rear guards with the help of olly... did one each :lol:
Hope you didnt do it like this
