Bennoz 6A13 Conversion
Due for dyno tomorrow! Today we've just gotta install a new electronic boost controller, rewire the coil packs & bleed the clutch :)
There are a few other things that need doing as well, but they can wait. Things like regassing the air con, rewiring the amp & sub etc. Trivial stuff.
And yes I have a massive erection. And yes Aza you can polish those lights & pipes :P
Bennoz wrote:Due for dyno tomorrow! Today we've just gotta install a new electronic boost controller, rewire the coil packs & bleed the clutch :)
From the sounds of it, it wont be the only thing he is polishing:lol:
:lol: ^^^ the cold shower fixed that problem lol
FTO_GPvR
Post by FTO_GPvR »
Awesome Ben. Goodluck with the dyno tomorrow and hope u get the power figure u want :D
Would u be coming to the cruise on the 16th if your car is all ready by then?
nvr2low
Post by nvr2low »
get a gizzmo man well i been told to get that one as they are the best and are so easy to use mate.
FTO_GPvR wrote:Would you be coming to the cruise on the 16th if your car is all ready by then?
Possibly, I'll see how I go. Still got a few things to sort after the motor is right.
FTO_GPvR
Post by FTO_GPvR »
Ok cool, thats alright :)
Goodluck with everything :)
yano
Post by yano »
hahaha, there's a lot of 'shining' going on by the sounds of it. Bennoz, I thought the haltech ecu just used your factory solonoid to control boost up to a certain psi? Can't remember how much though, but if you needed more you're able to get external sensors which would allow you to run whatever you wanted.
You better be getting the eboost 2 and not the street boost!! If you're getting the street version, save your penny's and get a greddy profec 2 ebc which will be cheaper and better overall. Hell you should be able to find an apexi avcr around that price range too which is an awesome little unit.
FTO_GPvR
Post by FTO_GPvR »
Ben hows your car going? Is it finished? Has it been tuned and dynoed?
Not yet! Its so close now, I've got a semi all day everyday :lol:
Worked on it all day yesterday (hope my boss isn't reading this!) and got a sh*t load done. I untwisted one of my coilovers & solved the problem that was causing it (a problem the car has had for years) with a large hammer & a pneumatic hand held belt sander. I plumbed in & wired up my new boost controller, I wired back in my sub & amp as the battery has been moved to the boot, then bled my clutch (and fixed a leak it had in the line, again something its had a problem with for some time.)
I even moved my chair back into position & adjusted the mirror :lol: God its good to feel the clutch pedal with some weight under it again. Also re-lubed up the quickshifter in preparation. Also sorted through all the boxes of left over bit & tossed what we didn't need & brought the rest home for spares.
There's only 1 thing left to do before dyno & thats wire in the coil packs. Couldn't do it yesterday as the guy that does all that wasn't in. Im happy to do it myself, but Im not 100% sure what wire goes where.
Post dyno, there are 3 things left to do, finish up the new intake pipes (and filters,) make up a catch can which will gather up all the manifold pressure lines & hook the air con back up. The air con will be a little fiddly as we've had to move a lot of the lines around. There'll be some oxy & bending required there.
yano wrote:You better be getting the eboost 2 and not the street boost!! If you're getting the street version, save your penny's and get a greddy profec 2 ebc which will be cheaper and better overall. Hell you should be able to find an apexi avcr around that price range too which is an awesome little unit.
Apparently, (and this is where the turbo talk befuddles me) the Haltech will do a majorty of the boost management, but with the aftermarket wastegates I have, we need a basic boost controller to set them.
I didn't need any of the fandangled features of the eboost 2, and thank god because its a f**king hideous gawdy gauge. The pro street was enough, and got it at trade price.
*learning cap on*
How can the haltech control boost??
*also puts learning cap on*
Apparently its got "Open or closed loop boost control ( Road speed, RPM or gear based mapping)"
There's a vacuum line nozzle on the ECU itself.
Bennoz wrote:There's a vacuum line nozzle on the ECU itself.
Really? very interesting, im impressed. So vacuum hose actually goes into the cabin? Or does it have a senor first then wires into the cabin?
Sorry if Im hijacking your thread.
Any new updates Ben ?
FTO_GPvR
Post by FTO_GPvR »
^ yeah been waiting awhile but no updates lately :twisted:
Was at the stage of turning her over yesterday. It didn't want to fire thou :(
Thinking we got the firing order wrong..
Bennoz wrote:Was at the stage of turning her over yesterday. It didn't want to fire thou :(
oh no don't say that things are going south again :tard:
bangs head on wood for more luck that it gets fixed soon.
Its cause we've gone with the individual coils packs. Got a 1 in 6 chance of f**king up the wiring of the firing order :lol: Hopefully they'll get it sorted.
Its alive!
Stay tuned for figures.
