[b]FTO Pro's and Con's Forum[/b]
khunjeng
Post by khunjeng »
Spud wrote:Wow that's pricey oil. Which one do you recommend khunjeng?
http://www.redlineoil.com.au/product-ordering.asp
RL106-4 10W30 Engine Oil...u will need a big and a small one to get 5L
the redline 10W-30 film thickness is as thick or thicker than that of a mobil 1 0W-40 fyi and its sheer rating is the best on the market.
Ester has been added to some engine oil for it polar effect which 'cling' onto any surface it pass thus lower the startup wear. Oh not all oils are added with ester as ester are 5 times more expensive than mineral base stock.
Now you know why Redline expensive when compare to normal synthetic...
Some oil i know that contain ester
Redline - mostly ester base
Motul 300V - mostly ester base
Fuchs silkorene - mostly ester
Delvac 1 - small percentage of ester
Magnatec - unknown percentage of ester (likely small amount)
