Did you really have one Kevin?
FTO338 wrote:GTsT comes with T28 turbo, which are similar to the SR20DET Silvia & GTR. But each model have slightly different compressor housing & exhaust housing.
GTST has a T3 Hitachi turbo. I wouldn't call it similar as the flanges are totally different - and there's no point comparing housing differences then.
FTO338 wrote:As the the idea of a turbo timer is to let the compressed hot air travel out of your exhaust, but if you leave it too long then the engine will build up the heat again, just like any car who been sitting at idle too long.
I disagree - not really anything to do with your exhaust (which isn't 'compressed' anyway). Turbo timers allow oil to pass through the lines and cool the turbo bearings, shafts and turbo seals. If you shut down a turbocharged engine straightaway after a hard run, the hot oil will potentially 'bake' and (in a worst case scenario) seize the turbo.
FTO338 wrote:And also remember the series one & two parts are not interchangeable. Well most part at least.
Actually virtually all of them are. Only thing that basically isn't is the front bar due to the different shaped lights, front bar and bonnet.
