RPW Extractors *Close*
- ph3var
- ph3var
- Mitsiman
- BuCkEt
I too am seriously interested.
Just to clarify however:
Total price of the RPW Extractors to my door is $616.00 under normal conditions.
Total price of RPW Extractors in a group buy of 10+ units is $550.00
If you are after HPC Coating for both headers it is an additional $400.00 if 10+ RPW Extractor units are purchased.
Right...am I missing anything??
G_A_V
- wildfaye
Dave, am i rite to say that intl customers done have to pay gst?Mitsiman wrote:Yes we can certainly deal with an international customer. The package will weigh approx 8kg and we would ship via Australia post international economy air freight which is around $120.00 AUD$ incl insurance.
If we get the sales (unlikely but I will throw it out there) of up to 20 units then we will do better on the pricing again by around another $15.00
so its jus 500+120 altogether?
Will u do a special price on the Throttle Body & Intake Manifold Thermo Block Spacers if we get the extractors from u?
Sam
G_A_V
Any exhaust shop could fit it, I would imagine somehwere between 150-200 to fit. If you want some performance mods, exhaust and intake is the best way to started wrote:Where can I have it fitted? how much (for fitting)? I wanted to do some mods on my car, just dont know anything about them. I want to join the group buy if possible.
- ph3var
- Mitsiman
Correct that international customers do not pay local GST or taxes.
I can do a slight discount on any other goods purchased at the same time as the extractors, but not to the same margin as what I have done with the extractors and FPR units.
With fitment, any reputable firm can fit these - just the cursing and swearing on the rear bank is normal.
We foudn that when fitting the front units, unbolting the front thermo fan and then refitting it afterwards made the front fitting a lot easier cause it provided more room both removing and fitting the new units. A little trick we learnt
With the rear ones - sorry they are just plain hard to remove cause there is so little room. Once there off the new ones take bugger all time to fit up.
I woudl allow at least 2 hours min tofit these up but it usually takes up to 3 hours. 2 Hours to remove teh stock system and around 1/2 hour
- Mitsiman
No there is no additional discounts. This is a specific group buy which excludes all other forms of car sponsership etc.
If you wanted to grab a set right now we have them in stock but you woudl revert back to normal pricing and club discount pricing if your club is on our sponsered list like MOGWA etc. This discounted price we are offering is greater than that of a normal club sponsership anyway
- spetz
Can you tell us the price of the extractors with the MOGWA discount?
As I will have the money in about 1 week and I am worried that if I wait for the group by I would have slowly wasted money.
I have been planning on buying these for months but unfortunately never had so much cash considering I want extractors + HPC coating + FPR + Stainless steal high flow cat + postage + fitting = roughly $2000
I assume the FPR is still $330 if I buy it without the group buy but with the extractors?
Will you give us FPR pressure settings or should we put the car on a dyno
- Mitsiman
- Mitsiman
HPC refers to High Performance Coatings which coats the exterior of the extractros with a ceramic silver polished coating.
This reduces heat radiation by aroud 50% over non heated manifolds and reduces under bonnet heat soak.
It also never fades and has a great show car look. Best of all the use of this will not cause the extractors to crack.
Heat wrapping etc of the extractors does not allow them to breath and will cause them to crack by remaining super heated.
Ceramic coating will also improve there effectiveness as it helps to promote the hot air to move down the pipes by remaining hotter and not cooling down until it reaches near the cat covnerter, which also makes the cat converter and O2 sensors more accurate as they need 900 degrees celcious to work properly.
So all is good but it comes at a price. This is probably not something you will be able to drive before /after and feel a difference. Its just an option that is becoming more and more popular.
- ph3var
- wildfaye
