Crappy Brakes
DZYRME
Post by DZYRME »
Jono wrote:Slicks? as in Semi slicks? or Road tyres turned into slicks? 8O
I think she was referring to road tyres turning into slicks. I saw her tyres the other day, and there wasnt much tread left on them. :?
ruchi
Post by ruchi »
big difference between bald tyres and slicks :wink:
MIVEC is My Friend :D
mxysxy
Post by mxysxy »
I was driving to home from work last night. After half an hour driving I realised that something wrong with my brakes.
Just before stopping, braking started to make some sort of strong grinding noise and front of the car started to vibrate a bit. Grinding and vibration was happening just before a complete stop.
Also happened all the time this morning, driving back to work as well.
Any idea whats wrong with the brakes?
Thanks.
Quattro
Post by Quattro »
How much brake pad do you have left??
What condition are the discs in?
Is the braking ability diminshed?
Hard to tell with out more info..could be a number of things.
mxysxy
Post by mxysxy »
To be honest, vibration at the front scared me a bit. So, I booked into Mitsubishi to get it checked for tommorrow.
Last time I seviced my car, which is about a month ago, %70 of the break pads were left.
Looks OK to me, there are no cracks od scrathes, however, I dont think I can understand if they were in bad shape. What to look for here?
I dont think it did, bit hard to tell
YYgirl
Post by YYgirl »
I have exactly the same problem, grinding noise comming from the front and doesn't stop very well. My disc rotors are below the limit with respect to thickness, could it be rotors at all??
smorison
The Godfather
Post by smorison »
brake upgrade kit is in the group buys forum now...
$1600 less 10% once three people are signed up...
YYgirl
Post by YYgirl »
anyone end up fixing their problems?
mxysxy
Post by mxysxy »
I ended up machining my front discs. Problem disappered for a week. However, all the grinding is back again now. :x
YYgirl
Post by YYgirl »
damn that sucks.... is your rotor the orginal set? what sort of pads are you using?
mxysxy
Post by mxysxy »
stock rotor, stock pads, nothing fancy. And it makes a terrible vibration just before a full stop. It almost feels like pads are trying to hold on to the discs, but keep sliding in a hopping manner. Dont forget to mention the noise as well.
Showed the car to Northern Mitsubishi, and they thought they fixed it, and charged me $100 for it. Damn think was not fixed at all.
Northern Mitsubishi has no clue about my car, they are hopeless, and will never use/suggest them again.
D-TRAIN
Post by D-TRAIN »
Just out of interest, at what speeds are you pulling up from to a complete stop? Or does it judder anytime you apply any pressure to the brakes, regardless of speed?
From FTO to EVO......
Jono
Post by Jono »
there could be a few reasons for the judder,
Wheel allignment
Wheel Balancing
Rotors are warped
id say warped rotors would be the cause. I had this on my car, only real way to fix it is with new rotors.
Jono
mxysxy
Post by mxysxy »
eg: city traffic,
doing about 40kmh--> red light--> normal breaking.
Just before a complete stop it is happening. lets say from 10-15kmh to 0.
It always happens just before a complete stop, and before this point everything seems fine, No noise, no grinding or no vibration.
YYgirl
Post by YYgirl »
that is the exact same problem i had
dunno whats wrong with the brakes............ :cry:
change the pads! Even if they look alright they could be glazed! It also a random thing.
If you have a groove in your rotor then change them.
I changed both my front rotors and pads for 100 bucks money well spent.
