You're not even touching the high beam.
Simply put, think of putting the same bulb that you put in to high beam, you are putting that exact same bulb in to your low beam as well.
That's all.
Hey that just click, so what happen if i decided to use a higher W rating HB3 instead???ruchi wrote: The only HB4 globes that I could find that offered a similar brightness were over $100. This solution costs about $30.
LOL!RichardH wrote:I'll be doing the Ruchi Not Rushi mod.
really good point - take note!RichardH wrote: It's worth noting that at no point in your hacking, filing, swearing frenzy of globe modification should you lay a finger on the actual glass bit. If you do, there goes any hope of the globe lasting any length of time. It has to be totally untouched, with no oily fingerprints.
