Guess my new vehicle
Re: Guess my new vehicle
That's rad. Big hair dryer then this:
That looks like an accident waiting to happen
spetz wrote:That looks like an accident waiting to happen
But I bet you it'd be the most fun accident you'd ever have!
And quite potentially your last, too, but that's beside the point.
From what I understand, the number of tractor accident related deaths is surprisingly high, and I guess that video shows why
Big rad boosted tractor & you're talking about death? You guys might be in the wrong forum!
Done a bit of work to the tractor...
New radiator, water pump, thermostat and coolant.
Engine oil and filter changed.
Air filter cleaned (it's steel wool soaked in a pot of engine oil)
New tacho and cable.
New temp gauge and sensor (tractor didn't have a temp gauge)
Gearbox/hydraulic oil changed.
Rear PTO seal and bearing replaced.
Brakes adjusted (it's good to have brakes that work, when I use a heavy implement on the back I need to used the rear brakes for steering)
Rear 3 point linkage arms overhauled.
