yeah look out for the frying the selector cables.
Rowans GPX Turbo Build
- bjk
- Totes
Re: Rowans GPX Turbo Build
That's definitely progress!
Rob Furniss
- bjk
- Totes
So when will the Furniss & Son drag race take place? :p
Rob Furniss
Round two will be when we're back in Perth probably.bjk wrote:So when will the Furniss & Son drag race take place? :p
Round one was in England when he had an Astra Turbo (manual), I had the Supercharged Tip FTO and it was on a 'private road' not an actual strip. The FTO came out on top.
We took both cars down to Shakespeare country raceway in the UK for a head to head but rain stopped the play (as is quite common).
He will beat me eventually if his car doesn't blow up as he's going to throw more money at it to run more boost than I will.
Rob Furniss
Need to get one of those inter coolers with the inlet and outlet on the same side
Rob Furniss
Yeah he's thinking about ditching the one he's got and doing that, it's got to be better than pipes all over the place.silverGPX wrote:Need to get one of those inter coolers with the inlet and outlet on the same side
- bjk
- Totes
Other option would be to try and do what FTO007 did and use a bend to run it in front of the cooler. Obviously still easier to grab a new one though
Rob Furniss
Didn't know about that, will have a look at his thread.bjk wrote:Other option would be to try and do what FTO007 did and use a bend to run it in front of the cooler. Obviously still easier to grab a new one though
- bjk
- Totes
Rob Furniss
That's just what i'm after, thanks mate.
- bjk
- Totes
All g.Rob Furniss wrote:That's just what i'm after, thanks mate.
Rob Furniss
Yeah that's what i'm thinking, I think it will be an easier install too.bjk wrote:All g.Rob Furniss wrote:That's just what i'm after, thanks mate.I'm guessing space in that area is pretty similar between prefacelift and facelift anyway. At least it would save it from cooler piping being all through the bay.
- bjk
- Totes
It's all progressing along quite quickly. What did the shop charge for the turbo piping out of curiosity?
Rob Furniss
$1100 plus a carton of beer, is that good?bjk wrote:It's all progressing along quite quickly. What did the shop charge for the turbo piping out of curiosity?
Rowans done the oil feed and return for the turbo but waiting on some more parts arriving now.
- bjk
- Totes
Sounds pretty good. I think what Vectose paid was in that range, but he'd already made one version so they had a template.Rob Furniss wrote:$1100 plus a carton of beer, is that good?bjk wrote:It's all progressing along quite quickly. What did the shop charge for the turbo piping out of curiosity?
Rob Furniss
Not up and running yet and already he's just ordered more bits!
Snow performance water/meth injection kit (progressive controlled), wants to keep me busy and distracted from my project I think.
At least I can have a play with it before deciding whether or not to put one on mine.
I think he's gone for one of these: http://www.snowperformance.net/Stage-2- ... -p/210.htm
Rob Furniss
Anyone know what the 4 ports on the turbo relate to in terms of oil and coolant in/out - is there an easy way to find out like is it obvious?
I'm presuming the smallest is oil in and the one opposite is oil out and then the slightly larger ones are coolant?
It's a GT35.
Cheers,
Rob
It's a GT35.
Cheers,
Rob
Yep, small ones oil in & oil out. Larger are water. They use a banjo style fitting like brake lines. You can buy them in kits for the GT35.
Rob Furniss
Thanks Ben.
The heater matrix has been bypassed since he bought the car cause it's knackered and got no plans to replace it soon, can he use those connections for water to / from the turbo or is that a bad idea?
