The bolt spacing on the hubs is the same, yes.bjk wrote:"Just" because you started with wheels as low offset as stock.Bennoz wrote:Just? Just... with a 20mm spacerbjk wrote:Well the Brembos clear (just). Any other issues you can think of?dstocks wrote:And then you find your rims dont clear the calipers...![]()
The RPF1s are +22, so no spacer required.![]()
But to confirm, the brake bracket setup from prefacelift to facelift is unchanged?
ATTKD Big brake kit - Just Jap
Re: ATTKD Big brake kit - Just Jap
- bjk
- Totes
So despite it being labelled for 97-01, it will fit earlier model years?
edit:
Never mind after looking on the site more I found this for the 94-97. http://justjap.com/brakes/brake-kits/at ... 94-97.html
edit:
- bjk
- Totes
The question is, is it worth the extra $200 to take the 330x32mm option on the four pots as opposed to the 304x28mm?
Personal choice really. 330mm is the same size as the Evo ones. If you're just using them for spirited street driving, I'd suggest the 304mm ones would be ample.bjk wrote:The question is, is it worth the extra $200 to take the 330x32mm option on the four pots as opposed to the 304x28mm?
Remember, the larger you go, the more reciprocating mass you add to the end of your driveshafts. I.e a loss of power.
- bjk
- Totes
Would it be fair to assume that the 304x28 is still a fairly common size of rotor?
Linkybjk wrote:Would it be fair to assume that the 304x28 is still a fairly common size of rotor?
Apparently so
- bjk
- Totes
Yeah, I'd googled it, just wondered if your prior automotive experience had some recollection of it already.
I'm emailing Darron at the moment, but rotors last a fair while don't they? Depending on quality/use?
- bjk
- Totes
Just adding in here as it's topical, but after a probably overdue Google search it appears Freaky Parts do a Wilwood bolt on kit for the FTO, doesn't mention how many pots the caliper is, and rotor is 294mm or something.
A French-guy owned and Taiwanese built company called Ceika (I believe was the spelling) also does multiple options for an apparently bolt on kit. Much in the vein of PB brakes, followed a thread on a BMW forum and the hardware is seemingly quality enough. Two year warranty on basically all of the kit.
A few of the guys on ftooc have the wilwood kit supplied by Stuart at Freaky (he's an ex owner, still a forum member over there I think).
- bjk
- Totes
You know any more about the kit?Rob Furniss wrote:A few of the guys on ftooc have the wilwood kit supplied by Stuart at Freaky (he's an ex owner, still a forum member over there I think).
- rock_it
Apart from it's expensive... And so are replacement rotors...bjk wrote:You know any more about the kit?Rob Furniss wrote:A few of the guys on ftooc have the wilwood kit supplied by Stuart at Freaky (he's an ex owner, still a forum member over there I think).
Best bet ... Do the Brembo conversion like Bennoz ... Or the GTO conversion like I have... That way you can buy stock rotors locally that are off the shelf, and save $$$$$
Not really, i've heard it's good but there have been a couple of issues with the hub needing a little bit of filing where the casting is rough but not on all.bjk wrote:You know any more about the kit?Rob Furniss wrote:A few of the guys on ftooc have the wilwood kit supplied by Stuart at Freaky (he's an ex owner, still a forum member over there I think).
It's not that cheap but none are.
I supplied Freak with the blueprints on how to create that kit. I got them off a guy in Barbados years ago. See if I've still got them somewhere.Rob Furniss wrote:Not really, i've heard it's good but there have been a couple of issues with the hub needing a little bit of filing where the casting is rough but not on all.bjk wrote:You know any more about the kit?Rob Furniss wrote:A few of the guys on ftooc have the wilwood kit supplied by Stuart at Freaky (he's an ex owner, still a forum member over there I think).
It's not that cheap though.
- bjk
- Totes
I think it's just a bit over £500 which isn't too bad? Import duty is a bit of a pain, mind.
The Ceika kit is tempting despite some reviews, I think I priced up a 4 pot kit with 330x32mm rotors for about 1300 or so...
- rock_it
Yeah, doesn't seem too bad then ..
If you went my way... Probably looking at something like :-
$300 rotors (Local off a 350z)
$300 for used GTO callipers. (Think I paid $350)
$200 for bracket
So already $800.. With no pads, and no lines... Obviously you can get cheaper rotors, but there is a comparison to an off the shelf kit. And assumes you don't need to rebuild the callipers...
$200 for bracket
- bjk
- Totes
Yeah, a few of the BMW guys have used them. Someone had them installed before their ownership on their Porsche GT3 or something. Lots of pics on their Facebook of it being tracked/drifted.
- bjk
- Totes
Dammit, saw the $ on the website and because I am stupid assumed it was AUD.
Kit mentioned earlier is actually just over 1600..
- kiz
- SA Coordinator
Are you looking at going over the top with brakes, or do you have a future project in mind requiring larger brakes than stock?
1998 Mitsubishi FTO GPVR AERO
- bjk
- Totes
Not too over the top. Wanting to keep my RPF1s is a good limitation for the moment. Basically I'm only really looking into because I have the Brembos, which work fine and everything but I'm not sold on the bracket/hub modification. So since I can sell them (hhopefully) a new BBK will cost less than it would otherwise.kiz wrote:Are you looking at going over the top with brakes, or do you have a future project in mind requiring larger brakes than stock?
I don't necessarily have a future 'project', but I have some ideas, so I figure why not.
- kiz
- SA Coordinator
Would it not be easier just to source stuff for your existing brake setup, rather than trying to sell the old ones and buy new ones?
