Potential DIY day
- c0n13oX
- Nacho
Re: Potential DIY day
How come?
I would have come if I didn't have to replace a temperate valve at home. Was a toss up between helping someone swap an engine or being able to have hot water in the shower.
- c0n13oX
Well it was only 3 of us there. 2 of us wouldnt of known a compressor from a starter motor
I woulda picked hot water too
- FTOcrazy273
Nacho wrote:How come?
SchumieFan wrote:FAPTASTIC!
Excuses! haha i pulled an engine out today without a crane and properly too lol it shouldnt take too much man power lol
- FTOcrazy273
Sahin wrote:Excuses! haha i pulled an engine out today without a crane and properly too lol it shouldnt take too much man power lol
Give us a DIY guide then? How'd you do it
Its pretty easy lol
drain all fluids first (coolant, oil, power steering fluid, gearbox fluid (if you want))
take rad out (auto has 2 ATF cooling lines you need to undo)
Battery and intake pipe (box if you have it)
unplug every plug and pull wiring loom off the engine and gearbox (its easier to take out the gearbox with the engine i found) (includes take the intake manifold off so you can undo the injector harness)
undo the air con compressor from its bracket and leave lines on if you want to keep the gas in the system and pull it up so it hangs over the front of the car and not in the way (not needed if your car has no aircon gas, just undo the lines from the compressor)
undo the selector cables (either manual or auto)
manual needs the clutch fluid line disconnected from the slave
undo power steering lines and any vaccuum lines from engine
undo heater core hoses
undo fuel lines from fuel filter
drop the Y pipe off the exhaust
undo cross member
and use whatever method you want to lower engine to the ground as all thats holding it in now is the top 2 engine mounts (4 bolts)
I MAY HAVE FORGOT SOME THINGS lol
undo cross member
- Herron
You selling the car or something FTOcrazy?
http://www.carsales.com.au/private/deta ... =3&sdmvc=1
- FTOcrazy273
I was going to Herron, but i'm not anymore I was able to sell my other car so now i'm able to keep my FTOHerron wrote:You selling the car or something FTOcrazy?
Thanks Sahin. Sounds pretty complicated for a noob like myself i'm still learning the ropes!Sahin wrote:Its pretty easy lol
undo cross member
