Caliper Bolts
Re: Caliper Bolts
Sahin wrote:
fraz91 wrote:
Daniel2019 wrote:
Shhtuart wrote:Oh god you loctite'd a caliper bolt? Good luck next time you need to change the pads over.
Stilsons.
Breaker bars work better :cheeky:
Or just borrow Sahin for a day. He'll undo everything in your engine bay and under your car with his bare hands. :(D):
I've never had a bolt I couldn't undo... And never have I used a breaker bar lol
Helps if you're working on real cars though sahin :clown:
Re: Caliper Bolts
Shane001 wrote:
Sahin wrote:
fraz91 wrote:
Stilsons.
Like 300zx's? :D I'll come be in you pit crew Shane! My name is also Shane so we would get along ;)
Re: Caliper Bolts
Sahin wrote:
Shane001 wrote:
Sahin wrote:
fraz91 wrote:
Stilsons.
:lol: no I was referring to real cars vs tonka trucks :lol:
But yes, pitcrew welcome regardless ;)
Re: Caliper Bolts
Sahin, I have a challenge for you ;)
Find yourself a 1JZGTE engine, factory original with say 100K km on it, that has never had the front crank pulley removed.
If you can remove that front crank pulley bolt in under 5mins I'll be impressed. Hell if you can remove it in under half a day you'll be doing well :lol:
Re: Caliper Bolts
It would make him angry.....
You dont want to see him angry.....
Re: Caliper Bolts
Taz wrote:It would make him angry.....
Re: Caliper Bolts
Shane001 wrote:Sahin, I have a challenge for you ;)
I removed the harmonic balancer bolt on the FTO with a socket set lol
I dunno how much more a 1jz bolt is torqued up but it can't be too much harder lol it was a *~delightful!~* job to do with a socket set though lol f**king loctite!
Re: Caliper Bolts
The FTO is easy, comes straight off, 1JZ is from memory 280ft-lb and fully loctited, the entire f**king bolt :evil: :lol:
Re: Caliper Bolts
Well the bolts weren't exactly tight to my satisfaction... You know when they go in a little TOO easily?
'tis all good though, installed some new pads while I was at it. 8)
Re: Caliper Bolts
Shane001 wrote:The FTO is easy, comes straight off, 1JZ is from memory 280ft-lb and fully loctited, the entire f**king bolt :evil: :lol:
About the same as a mini primary shaft gearbox nut. Locktite AND the steel washer folded over it :lol:
I had to put the gearbox under a car hoist (with car on it) and lower it onto the box to hold it in place, so I could hang off a 3 metre breaker bar with my 135kg dad :lol: We got it eventually, f**k did it make a noise! :lol:
Re: Caliper Bolts
8O
The Hulk MIGHT even break a sweat doing that...possibly...probably not :lol: ;)
How much torque do you reckon that is?
fraz91
Hair-do
Re: Caliper Bolts
Post by fraz91 »
Taz wrote:8O
I believe the technical term is "F***ing Tight Nm"
:troll:
Re: Caliper Bolts
ObsidianRadio wrote:Well the bolts weren't exactly tight to my satisfaction... You know when they go in a little TOO easily?
Thats because the bolt is the worng size!!!
Re: Caliper Bolts
Taz wrote:8O
I reckon 500-600!
Re: Caliper Bolts
Sahin wrote:I've never had a bolt I couldn't undo... And my dick is a breaker bar lol
EFA
