Moderators: IMC , Club Staff
fraz91
Hair-do
Posts: 881 jedwabna poszewka promocja
Post
by fraz91 » Mon Mar 04, 2013 2:34 pm
Sounds to me like a bearing isn't rotating freely inside the bearing assembly. Hence the scraping/whirring noise. If possible, pull a front hub off another car and fit it to yours (with consent of course) and see if that fixes it.
Not sure how a caliper could cause this issue, if it was sticking the brakes on then the car would pull one way and you'd be noticing heaps of uneven pad wear.
4.
1992 Nissan NX Coupe (club car and project car)
5.
1996 Holden SB Barina - "The Nugget"
6.
1996 Jeep XJ Cherokee Sport - The Budget Build
Astron_Boy wrote: No correction needed Gen Y, you are correct.
Bennoz wrote: My rubbing happens on the inside.
Posts: 8400 Joined: Sun May 27, 2007 5:00 pm
Post
by Astron_Boy » Mon Mar 04, 2013 2:42 pm
fraz91 wrote: Sounds to me like a bearing isn't rotating freely inside the bearing assembly. Hence the scraping/whirring noise. If possible, pull a front hub off another car and fit it to yours (with consent of course) and see if that fixes it.
Definitely doesn't pull, that's for sure.
Posts: 5519 Joined: Wed Oct 05, 2011 10:38 pm
Post
by Sahin » Mon Mar 04, 2013 3:01 pm
Astron_Boy wrote: fraz91 wrote: Sounds to me like a bearing isn't rotating freely inside the bearing assembly. Hence the scraping/whirring noise. If possible, pull a front hub off another car and fit it to yours (with consent of course) and see if that fixes it.
Gotta hate that...
Post
by Astron_Boy » Mon Mar 04, 2013 3:32 pm
Sahin wrote: Astron_Boy wrote: fraz91 wrote: Sounds to me like a bearing isn't rotating freely inside the bearing assembly. Hence the scraping/whirring noise. If possible, pull a front hub off another car and fit it to yours (with consent of course) and see if that fixes it.
Gotta hate that...
Yeah, kinda sucks......................................
Posts: 4154 Joined: Mon Oct 29, 2007 5:00 pm
Post
by vipfto » Mon Mar 04, 2013 5:57 pm
im with Fraz on this bearing rooted first of all remove caliper and disc from assembly then spin it noise still there and bingo bearing it be. Note you dont have to have movement to have stuffed bearings could even be dry with no grease
Post
by Astron_Boy » Mon Mar 04, 2013 6:20 pm
Cool, consensus says bearing which is what I was hoping for.
It also means I paid some schmuck years ago for sitting around.
fraz91
Hair-do
Posts: 881 Joined: Sun Jan 17, 2010 6:00 pm
Post
by fraz91 » Tue Mar 05, 2013 8:11 am
Astron_Boy wrote: It also means I paid some schmuck years ago for sitting around.
Wanna pay me to sit around instead?
Serious question though, do the FTO's have replacement hubs available that can be bolted straight in, or do you have to press the bearings out and back in? If it's the former, I'd be more than happy to help swap the new one in for you
4.
5.
6.
Post
by vipfto » Tue Mar 05, 2013 8:14 am
Press jobs
Posts: 23676 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Tue Mar 05, 2013 8:23 am
You can just swap out the hub though.
fraz91
Hair-do
Post
by fraz91 » Tue Mar 05, 2013 8:38 am
Bennoz wrote: You can just swap out the hub though.
Cool. Means you also have spare wheel studs should one ever be stripped.
4.
5.
6.
Post
by Bennoz » Tue Mar 05, 2013 9:52 am
fraz91 wrote: Bennoz wrote: You can just swap out the hub though.
Post
by Astron_Boy » Tue Mar 05, 2013 10:17 am
Bennoz wrote: fraz91 wrote: Bennoz wrote: You can just swap out the hub though.
I think he means Lawso.
fraz91
Hair-do
Post
by fraz91 » Tue Mar 05, 2013 10:21 am
not necessarily lawso, but any tyre shop really. Have seen and replaced many stripped wheel studs on trucks at work. Having a complete hub assembly available means when you replace the original, you can keep the old studs as spares should the need arise.
4.
5.
6.
Post
by Astron_Boy » Tue Mar 05, 2013 10:25 am
So, tyre shops Lawso stuff also?
Well sh*t.
Post
by Bennoz » Tue Mar 05, 2013 10:25 am
Posts: 3952 Joined: Sun Nov 28, 2010 8:45 pm
Post
by Vectose » Tue Mar 05, 2013 10:54 am
The difference is that Lawso strips it by hand, tyre shops strip it with a rattle gun.
Bennoz wrote: Technikhaus wrote: What is in said Bens big penis by the way?
A whoooole lot 'o jism
fraz91
Hair-do
Post
by fraz91 » Tue Mar 05, 2013 12:10 pm
Vectose wrote: The difference is that Lawso strips it by hand, tyre shops strip it with a rattle gun.
Yep. Technically speaking, the tyre shops are 1-upping lawso in this instance
4.
5.
6.
Posts: 5756 Joined: Tue Oct 04, 2011 1:34 pm
Post
by bjk » Tue Mar 05, 2013 12:16 pm
fraz91 wrote: Vectose wrote: The difference is that Lawso strips it by hand, tyre shops strip it with a rattle gun.
Is such a thing possible?
Post
by Astron_Boy » Tue Mar 05, 2013 12:28 pm
bjk wrote: fraz91 wrote: Vectose wrote: The difference is that Lawso strips it by hand, tyre shops strip it with a rattle gun.
Post
by Bennoz » Tue Mar 05, 2013 12:30 pm
Astron_Boy wrote: bjk wrote: fraz91 wrote: Vectose wrote: The difference is that Lawso strips it by hand, tyre shops strip it with a rattle gun.
