How you's doin
Re: How you's doin
Oh thank god it's not Ollies sh*t box lol
- ftoguy2012
- ObsidianRadio
Re: How you's doin
Your friends have nice cars!
Re: How you's doin
Yeah except for the supra and the lancer!ObsidianRadio wrote:Your friends have nice cars!
- den0va
Re: How you's doin
Is that a halo + projector foglight unit I see? :O
- ftoguy2012
Re: How you's doin
Hahahah, and I'm not entirely sure, as far as I know there stock, so probs projectors but not halo's
(Don't use fog lights ever where I live)
Re: How you's doin
They look to be the same as I have..
- ftoguy2012
Re: How you's doin
That's them, mine are yellow though, harder to see the halo, what bulbs do they take as 1 of mine is blownTechnikhaus wrote:They look to be the same as I have..
Re: How you's doin
to my knowledge they take CCFL tubes...
Not too sure if you can replace them though...
- kiz
- SA Coordinator
Re: How you's doin
Definitely aftermarket. Those are not stockftoguy2012 wrote:Hahahah, and I'm not entirely sure, as far as I know THEY'RE stock
1998 Mitsubishi FTO GPVR AERO
- Shhtuart
Re: How you's doin
Those headlights don't look like HIDs.
What type of bulb to they have?
- ftoguy2012
Re: How you's doin
I honestly have no idea lol, but they are HIDs. While I'm on the subject, is there an easier way of removing the bulbs/parkers other then takin the front bar off? If not, what's the easiest way of taking the front bar off (as in where are the bolts located)Shhtuart wrote:Those headlights don't look like HIDs.
Cheers
Re: How you's doin
If you jack the front up, you will be able to access them from behind. You may or may not have to remove plastic under the car.
- shadowarrior
- Tightarse
Re: How you's doin
I couldn't get the damn headlights off without taking the front bar apart. 3 or so bolts on top... 4 (2 on each side) at the bottom and the plastic wheel guards should let you slide the front bar out. Easy access to the headlight globes and horn from there.
