DIY Day Sydney (Round 2)
- zuihoujueding
Re: DIY Day Sydney (Round 2)
LOL. mate, it has never happen and wont let it happen!
There is no need to disconnect all vacuum hoses and connectors, the plenum can simply be moved out of the way after disconnecting only the brake booster and map sensor hoses. There may be one more but I can't remember.bass_twitch wrote:Just ensure you don't forget all the vacuum pipes!
- bass_twitch
Yeh, but don't forget to plug in anything you do unplug!Vectose wrote:There is no need to disconnect all vacuum hoses and connectors, the plenum can simply be moved out of the way after disconnecting only the brake booster and map sensor hoses. There may be one more but I can't remember.bass_twitch wrote:Just ensure you don't forget all the vacuum pipes!
- Lawso
- Penis Fingers
LOOOOOOOOOOOOOOOOO0OOOOOOOOOOOOOOOOOOOOOOOOOOL!!!!!!!!!!!!!bass_twitch wrote:Yeh, but don't forget to plug in anything you do unplug!Vectose wrote:There is no need to disconnect all vacuum hoses and connectors, the plenum can simply be moved out of the way after disconnecting only the brake booster and map sensor hoses. There may be one more but I can't remember.bass_twitch wrote:Just ensure you don't forget all the vacuum pipes!
I don't need to troll this thread, bass_twitch is doing an awsome job of it
Well done, makes me feel all warm and tingly
- bass_twitch
PHIL069 wrote:I don't need to troll this thread, bass_twitch is doing an awsome job of it![]()
Well done, makes me feel all warm and tingly![]()
Funny thing is, it was originally meant as a genuine thing to watch out for.
When I did mine we missed a hose at the back and it was stalling in 2nd and 3rd.
Wasn't a nice run around the block.
Once the hose was back on =
Summary of the thread so far!
It's all bass_twitch's fault
lawso wrote:LOOOOOOOOOOOOOOOOO0OOOOOOOOOOOOOOOOOOOOOOOOOOL!!!!!!!!!!!!!bass_twitch wrote:Yeh, don't forget to unplug!Daniel2019 wrote:Rears it is! Just dont f*ck it upbass_twitch wrote:+1 for above. Rears aren't too bad, - can take a bit longer than a couple of hours if you have never done them before and you are being really cautiousVectose wrote:Yeah, rear not that hard. I can tell you what to do.Shane001 wrote:Rear not that difficult. 1 to 2 hours tops.Daniel2019 wrote:I think maybe rob said he knows how. Youre more than welcome to do itzuihoujueding wrote:I probably can do the front with my eyes closed. but never done the rear before will be great.Daniel2019 wrote:fronts no, rears yes. Im happy for you to do it.bass_twitch wrote:Man up and do it!- It's not that bad!
Sorry, I was bored.PHIL069 wrote:I don't need to troll this thread, bass_twitch is doing an awsome job of it
It seems that saturday 5th is now unavailable for me as I have no money and had to pick up a shift - was planning on getting some but didnt go according to plan
- been off work for two weeks due to exams. Next saturday or sunday looks like the best option as I'll have a weeks worth of pay. Is everyone OK for 12th or 13th? Most likely 13th.
- bass_twitch
*scratches head*PHIL069 wrote:Sorry, I was bored.PHIL069 wrote:I don't need to troll this thread, bass_twitch is doing an awsome job of it![]()
It's all bass_twitch's fault![]()
Astron_Boy wrote:The 13th being mothers day...
For your informatory consideration.
- aza013
- NSW Coordinator
Well if things are needed to be done this weekend I can offer my place
Let me know what every one wants, or if it's not priority I will set one up with more notice.
Thaaank you azaaaa
- aza013
- NSW Coordinator
If any one wants help this weekend let me know and I will pm you my address.
- Shazzam
Do you guys know how to fix a sloppy indicator arm and horn?
Indicator arm no, horn yesShazzam wrote:Do you guys know how to fix a sloppy indicator arm and horn?
- sublime19
- Sooty!
Depends - Do you use your left or right hand to control the indicator?Shazzam wrote:how to fix a sloppy indicator arm
- zuihoujueding
sorry not able to make it as im heading up newc.
- aza013
- NSW Coordinator
Well at this point no one needs work done so it's looking like a nonevent.
I will set one up for the start of next month.
- bass_twitch
aza013 wrote: I will set one up for the start of next month.
If it is sat, I'll try to be there
