silverGPX wrote:Hey Rob! Good to see your in AUS now.
Id love to supercharge my FTO, it sounds so much easier than turbo charging.
Im thinking about taking out a loan to do this
My opinion is that it's easier and less stress on the engine.
Hardest bit is mounting the charger and associated idler/tensioner pulleys as there's no off the shelf brackets to do this. Luckily I had a spare engine to mock-up the brackets, really wish i'd got them copied before selling the car.
I actually did remove everything and make paper templates just before selling the car and moving here but somehow they've vanished.
Very basic list:
Supercharger (I used an Eaton M45 from a mini cooper s)
Larger injectors (CDH-275)
Engine management (emanage blue will do)
Spare intake plenum to cut down and make shorter
Ally plate to make the brackets
Idler/tensioner pulleys
Bypass valve
Small intercooler
IC pipework
If I do buy another FTO I will most likely charge it and start a build thread on here, should be easier 2nd time around.
And I'll be watching eagerly watching and learning,
Lol make sure you do a photo DIY!
Found another one but it's unlicensed, very cheap but high km's, should I stay away from it or is it not a big deal buying an unlicensed car?
Haven't looked at it yet so i'm not aware of any issues that it may have.
Rob Furniss wrote:Found another one but it's unlicensed, very cheap but high km's, should I stay away from it or is it not a big deal buying an unlicensed car?
No and i'm wondering why it's been unlicensed for 12 months, and he doesn't know if it's a GR or GPX.
I'm trying to arrange to view it, assuming it is in good condition how easy is it to get it registered in WA and can I even drive it home after purchasing?
Thanks yotka, I don't mind paying for inspection as long as there's nothing wrong with it and it's going to pass lol but I don't know why he just doesn't do that, unless he's expecting it to fail.
Edit, just seen your other post.
Don't suppose you happen to know any mobile mechanics?
If not I will do a google, i'm sure there will be a few around in Perth.
Or maybe I should just wait a while longer, haven't really seen what i'm after yet.
