have a nice day
does rolling down a hill give me any killer wattage?SchumieFan wrote:id be surprised if the zuk pulled anything over 0KW
lol, as nice as all that is ^ I'd say all you'll get is 2 quick runs for 60 bucks and a pretty graph print outShane001 wrote:Hi azza,
Depending on how many people are interested, it may be better for us to book half a day / full day, rather than being charged individually, then just split the cost amongst us (obviously you need payment upfront lol!). Maybe find out their hourly rate and compare which way will be the better deal. An advantage of booking a half or full day is we can then play around a bit with different things to compare performance gains/losses at our leisure, without being pressured based on individual time allowances.
I'm still in depending on date but to make it worth while I would need to confirm the following;
Two key graphs we will need for each car, including load and correction values used;
KW / AFR vs RPM.
KW / Torque vs RPM.
Also the full data file for each run in Excel or Word, in 50rpm increments.
Very important also that they synch each cars tacho to the dyno. No point doing comparisons off road speed, needs to be off engine rpm.
The data file should include recorded road speed though.
I need to confirm that I will be allowed in the passenger seat during my dyno runs.
If we do book a half or full day we should designate one or two cars to do some testing.
Simple things like comparing intakes, easy bolt on bolt off items.
I'd also like to compare disabling the power steering (ie removing the belt).
wtf is your pciture of? I can't figure it out! hahaRALLiART_FTO wrote:We should make another dyno day around November/December
