4000 rpm
Dave1971
Re: 4000 rpm
Post by Dave1971 »
I8A4RE wrote:You have a TIP(auto) I bet?
Yes it is a tip auto.
Re: 4000 rpm
Mine did this once, back when I first got the car. It was a stinking hot day and drove into a bottle shop. I left the car running and when I drove off down the street it did this. I replaced the alternator (not for this reason) and it never did it again. I assumed the alternator fixed the problem but I can not confirm that. I know the GPX have a fail safe in them to stop them hitting MIVEC when the alternator is screwed, so maybe it is the same for the gr's
Dave1971
Re: 4000 rpm
Post by Dave1971 »
Am not sure if its the alternator, as i replaced it a few months.
Re: 4000 rpm
Sorry then mate I have no idea as mine has never done it since. Have you checked your error codes?
Re: 4000 rpm
Dave1971 wrote:Am not sure if its the alternator, as i replaced it a few months.
did they replace with gr or gpx alt? 2 or 4 pin style? as while they will work in either car it wont run correctly
Dave1971
Re: 4000 rpm
Post by Dave1971 »
No i replaced the alternator for a direct replacement which was a 2 pin.
Dave1971
Re: 4000 rpm *fixed*
Post by Dave1971 »
Found what I believe was the problem, it was a loose connector under the steering column. I done a lighting mod a few months back and the connector must of worked it's way loose, I am well happy :D :D :D :D :D
Re: 4000 rpm
:lol: win
Re: 4000 rpm
WOOOHOOO WIN alright
xj265
Re: 4000 rpm
Post by xj265 »
Good to hear mate!
Re: 4000 rpm
Something so little can cause so much frustration to one.
Dave1971
Re: 4000 rpm
Post by Dave1971 »
So i thought it was the mod, i have soldered every think up in that area so it leads me to another connector the one under the fuse box by the air filter. I was moving the wires around that area and it sprang back to life, when it stops raining am going to try and disconnect it and clean it as its the only two things that had a impact with the revs.
Dave1971
Re: 4000 rpm
Post by Dave1971 »
I have decided to change the spark plugs and lead which hasn`t solved anything, any more ideas to solve this problem.
Dave1971
Re: 4000 rpm
Post by Dave1971 »
I still haven`t sorted it, what i have done is locate it to a certain area. I pulled on the air flow meter wiring and it went over 4000rpm, i suspect it maybe a broken or damaged cable.
Does anybody know if there are any connections in the bungle of cables before it goes back to the ECU, as i plan to strip off the covers and inspect for damage.
Or if some one with a GR model can give me the resistance measurement on the air flow wiring, so i can move them around to see if it changes.
Dave1971
Re: 4000 rpm
Post by Dave1971 »
Problem still here, any more ideas really need to identify whats causing this.
Re: 4000 rpm
maybe try getting another maf sensor?
Also maybe a new plug for it?
Dave1971
Re: 4000 rpm
Post by Dave1971 »
silverGPX wrote:maybe try getting another maf sensor?
I didn`t know the plug were inter change able.
Re: 4000 rpm
There not like cut it off and wire up a different one
bduffman
Re: 4000 rpm
Post by bduffman »
dose the engine light come on ( i know with my gr one day i tryed starting it with out the wire in the maf and sorta coughed and splatted ) also when i drove one time it came loose ( not out but lost connection for a second ) and it slowed me right down ( mines a manual )
so not sure how the auto works but it may have a fail safe somehow
Dave1971
Re: 4000 rpm
Post by Dave1971 »
Hi Chaps,
No engine management light on. :(
