Preparing for service. Double checking stuff.
Re: Preparing for service. Double checking stuff.
I8A4RE wrote:
Valandis91 wrote:My god the fuel filter was a bitch.
May i reiterate fuel filter is a BITCH
OMFG the fuel filter was a bitch.
I hear ya, did another one today it was the worst one I'd ever seen. Evoman, be proud :lol:
Thats why I relocated mine....Now its f**ken easy, I dont even crack a sweet however I do crack a beer ;)
Here's a pic of the one we pulled out yesterday. Was worse than mine!
Yeah that is fkn horrible 8O
Valandis91
Post by Valandis91 »
i seriously wish i took a photo of mine but i couldnt be bothered cutting it up.
finally tightened the top bolt and even that little leak made a difference. its all good now.
my god the increase in power is amazing. hardly have to accelerate anymore.
and when i do WOW. i reckon i could be closer to the 125kw mark now.
its running a lot richer at idle. the rest of the map is okish.
will wait for a dyno day. plus still no news with the verniers. thats the next thing to play with!
oh and loving the oil and oil filter ;)
Martini Oil FTW
Nice! Yeah shame you didn't open up the filter. We should start an 'fuel filter wall of shame' :D
FTO-BOY
Post by FTO-BOY »
Hey ben or any who has done the fuel filter..
What are the signs that needs a new filter?
U lot are a pack of girls :lol:
Fuel filter was a piece of piss, 35mins! That's with the air intake and plenum already removed, so allow an hour, hour and a half tops!
Def take the intake and plenum off to give you some room to move.
19mm socket on a breaker bar to crack the top nut.
Then a long 14mm spanner to crack the bottom nut.
I didn't even need to hold the filter with a 19mm spanner, just made sure I had a nice solid fit with the socket / spanner then a quick snap to 'crack it loose'.
Make sure you have a decent quality 14mm spanner with a nice tight fit, if you round this nut you're gonna be completely fucked :lol:
Remove the 2x 12mm bolts holding the bracket to the firewall.
Pop the brake line out of the plastic holder.
Undo the top and bottom fuel lines being careful not to drop the copper washers from the top fuel line, or get any dirt or sh*t falling into them.
Remove Filter still in bracket and swap with new filter, making sure to get the new filter in the same position in the bracket.
Mount the bracket with the new filter back on the firewall and snap the brake line back into the plastic clip.
Connect the bottom fuel line to the new filter.
Connect the top fuel line with the new copper washers that should have come with the new filter.
Torque the top fuel line bolt to 20 lb-ft.
Tighten the bottom fuel line to about the same or a bit more (25 lb-ft).
Be very careful not to over tighten the fuel lines.
Jobs done! :D
Vlandis re your leak, did you remember the copper washers either side of the top fuel line?
I cut the old filter in half but it was pretty clean, so I reckon it's been changed not so long ago. Still better to know I have a new one in there than not know what condition it's in.
Valandis91
Shane001 wrote:you lot are a pack of girls :lol:
what do you mean either side?
also what happens when you over tighten them? mines fine now i just tightened it!
Valandis91 wrote:what do you mean either side?
The fuel line that connects to the top of the fuel filter, should have a copper washer on the filter side, and a copy washer on the bolt head side.
bduffman
Post by bduffman »
What's that shane your nominating to install my fuel filter and rear shocks =) already installed the front ones
haha, no worries, we'll do a diy at my place and u can help me drop the gearbox, replace the water pump and re install the eManage ;)
And engine oil change, and front brake rotor indexing, and replace all the rocker cover up seals & gaskets, and... Got lot's to do before Bathurst 2011 :twisted:
FTO-BOY
Post by FTO-BOY »
Hmmm I got 630km out of this old fuel filter ( when I say old I mean I haven't changed it since I bought it 3yrs ago)
Oh and that's the same with the spark plugs.. 0.0
FTO-BOY wrote:Hmmm I got 630km out of this old fuel filter ( when I say old I mean I haven't changed it since I bought it 3yrs ago)
Geez u don't drive it much :lol:
FTO-BOY
Post by FTO-BOY »
Lol I meant 630km per tank of fuel.
evoman
Post by evoman »
Lol. I smell fuel filter changing war. I think it only took Ben about 25 mins to do mine. He didn't take anything off and I think I honestly only heard 3 occasions of profanities.
FTO-BOY, my car still managed 700kms a tank on the highway prior to changing the filter so given the state of mine I don't think milage is a good indicator of whether they need replacing. Maybe consumption gets between the worse the filter is lol?
+1 barked knuckles :lol:
Sweep
Post by Sweep »
Any chance of a diy with pics cos I wouldant even know where my fuel filter is :lol: :oops:
Looking at replacing the plugs soon so may do the filter at the same time :cyclopsani:
FTO-BOY
Post by FTO-BOY »
I'll volunteer for my car to be in the DIY! just need someone to write it and change my filter.. Hehe. Also might do the spark plugs with it.. Hmmmmmmmmm I think we need another DIY day? Lol
:facepalm2:
I got some time early Sat morning :lol:
Sweep
Post by Sweep »
:mrgreen:
