Yup when I had mine off for the turbo project it was clean as f**k! Oily but clean lol. and that was after 150 xxx odd kms.bduffman wrote:Also has any one ever removed sump and cleaned it out dose it get much build up in there
Just changed oil filter
Re: Just changed oil filter
- bass_twitch
So how do I do these things? (I wouldn't have a clue how to reset the ECU... ) We need a comprehensive DIY which is "how to do a full clean out and service" hahabduffman wrote:Don't forget
fuel injectors can get build up
Termo gaskets ( gets colder air into the engine )
Can't you just run a thinner oil threw the engine to clear it out
Also mayb reset ecu once you do the upgrades as it may affect fuel to air will make it run smoother
Dont worry about injectors or thermo gasket.
As for ecu reset just remove battery terminals for 5 minutes and then reconnect.
- bass_twitch
Sweet! That's an easy one! So I only do that once everything else has been serviced though?I8A4RE wrote:Dont worry about injectors or thermo gasket.
before or after makes no difference
- bass_twitch
- payaya
So true, what else is green in your engine.Bennoz wrote:Ewww, someones cooked a head gasket in a past life!
- Gholdwayne
resetting the ECU, you could say, would make the brain of the car reborn, to relearn everything, start fresh.bass_twitch wrote:and what would resetting the ECU do?
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
