Unfortunately the Willans 4x4 harness is not legal for road use.
However, the harness does come with eyebolts that you could fit to the car.
This way you can retain the standard seatbelt and just clip in the harness into the eyebolts if you track the car.
If you have any further questions please do not hesitate to ask.
Regards,
Joseph Lenthall
Revolution Racegear
N.S.W
P: (02) 9648 4044
Sorry Bushido, but I'm not willing or qualified to offer medical or legal advice
Edit: Also this doesn't come with eyebolts, just the belts, I need my eyebolts lol!
But these can be purchased separately, I'm sure they aren't expensive
I would probaly mount them on the rear seat mounts so two eyebolts for those.
Shane how did you mount the two bottom straps? Did you use the existing buckle on the seat and the one of the chassis?
questions questions....
Thats how I mounted the bottom 2, same holes as the seatbelts. One is on the side of the car, the left hand side one is where the latch bolts to the seat itself.
EDIT, found the pics
And I remembered, I had to cut some plastic out of the section that sits over the bolt.
The 2 side (bottom) belts would use eye bolts, u can see in the pics these have the click on connectors for the eye bolts. You cold probably use these where Ben has bolted his in the pics.
The 2 rear belts don't currently have connectors for eye bolts. These were wrapped around my rollcage. So you would need some kind of additional connector for the rear straps. Maybe similar to what Ben has done for the side ones.
shane can you take a pic of the rear belts where you wrapped them around your cage?
bushido wrote:shane can you take a pic of the rear belts where you wrapped them around your cage?
No
Cause they're no longer in the car and unless you have a roll cage then this is pointless
Seriously if u're interested in them best to drop by and have a look and I can show you / explain how they could be mounted. You will need to buy some eyebolts and possibly some clip connectors for the rear belts (same as on the side belts) as the rear belts currently have no 'connectors' on them.
Will all make sense when u see them in person. Sending photos back and forth will only confuse the issue more.
Ok I have now installed the harness. Its awesome! Guys can check iot out at the sunday meet
although I wasnt happy about the price I paid for 4 eyebolts and 2 belt connectors
I got off the base early today so I decided to treat myself. f**king 5 am starts in freezing weather.....especially at RAAF Richmond. My god its cold out there
