Approx $ for this service
- bduffman
Re: Approx $ for this service
Yea there are kits you can buy basicly just a hose and pump but if u put the hose on losen it then pump the brake fluid will come out just make sure you don't pump to much cause the master has to always be full
- vipfto
nope wrong for brakes start at the caliper that is furtherest away from master cylinder then work towards colsest one getting all old fluid out first then replacing with new same for clutch they are both very simple jobs.
but seriously there is only a solid 8 hrs labour there do the math
