ok then well it can only be from rocker gasket or cam seals then
so to be sure try and degrease and clean as much as you can then run engine for for a while until you can trace where the leak starts to appear from
seeing as you have just had timing belt done Im guessing you got those seals done too? But just note that they can leak even if just been replaced (not often but does happen)
i personally didnt get them done but the car has only done 118000km when i got it now it has 130000km, and i had a look a while back to see if the timing belt was done and it had a gates one so im assuming they would of done it. Are cam seals easy to do?
payaya wrote:Is that green sh*t coolant? Sure you don't have a head leak?? That white sh*t on your exhaust manifold looks like dried coolant (coolant dries white)
I was thinking that but realized its perfect place for grease to be thrown up from inner CV which he confirmed
