Anyone looking for some cash or alcohol?
nvr2low wrote:hey aza were did you get the short shifter from mate i want one and please explain what you change over mate.
It was all thanks to the KING of parts :king: DSTOCKS :thumleft:
as for the change over the battery whent into the boot giving me more room for shinnnnnnnny bits under the hood :twisted: .
nvr2low
Post by nvr2low »
haha ok is it the same one that u can get from rpw man. i meant how do u change the stick over mate..
lol the shifter is a C shifter from Japan.
as for changing it over well you will have to check with Ben on that one as I did not even get to see how he did it, He was that fast with it :twisted:
No probs mate ;) We had quite a successful mini DIY day! 1 set of rear GR droplinks changed, a rear camber adjustment, a quick shifter install & battery in a boot!
All you do is remove the centre console, remove a split pin from one of the selector cables, remove the 3 bolts holding the shifter assembly in & as you lift it out, pop the bottom of the shifter out from the lower selector cable (small spring clip)
Once you got the assembly out, them you gotta strip it down.
Need to undo 2 bolts & the spring flys off & the whole lot comes apart in your hands. Then you just pry the stick out from the plastic housing & push the new slector into its place.
Reassembly is the reverse of the above, only difference is, when you bolt the assembly back in, you have a thick sandwich plate that goes underneath the selector assembly. It comes with the shifter & it also should have 3 (longer) replacement bolts.
mz_madz
Post by mz_madz »
My car is all fixed :) thanks to Bennoz - you LEGEND!
Thank you for sparing your time!
It was really good to meet you, Karen & Aza :D
(Aza, I will see you on that cruise except I wont be putting my name down because I'm jinxed when it comes to that!)
No probs Madison!
FYI, those bushes I replaced will need doing again in the future, here's what you need to buy: http://www.camskill.co.uk/products.php?plid=m3b0s10p205
And Dras needs some bits too, so perhaps if you order everything together, you could save on frieght.
These are the bits he needs:
http://www.camskill.co.uk/products.php?plid=m3b0s10p151
http://www.camskill.co.uk/products.php?plid=m3b0s10p204
rynofto
Post by rynofto »
awww spewing i missed out on this. wouldnt mind having a look at how things are done. i am about 20 mins away from there and my fto needs some tlc.
Gholdwayne
Re: Anyone looking for some cash or alcohol?
Post by Gholdwayne »
Hey Ben!!
would you install my c's short shifter for a 6-pack pretty please ?? :roll:
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
mr-charisma
Re:
Post by mr-charisma »
was dwayne able to order a new one in from japan? or was it a spare laying around?
KJ_bob
Post by KJ_bob »
I love my short shifter, so much nicer to drive... not hard to install, there's a DIY gride with pictures getting around somewhere if you search the net
Gholdwayne
Re: Re:
ordered in from japan
97 GPX Icelle Blue
FTO[For The Orgasm]
