Thanx for your update rallymad, sucks your still having problems though...
Mine hasn’t thrown a belt since i put the 4pk on it. Don’t get me wrong, its tried to. The other day i found that on the p/s pulley (not tensioner) it had claimed over a grove away for the engine and toward the alternator belt. Don’t know if that tells anyone anything.
Anyway, im going to go replace the p/s tensioner in a bid to fix the problem. I cant see how it could be the harmonic balancer, as i would not of though it would wear its seal in 10 years (correct me if u think im wrong in thinking this), unless its have a front on crash. A guy that specialises in harmonic balancers had a look and didn't seem to think it likely to be the problem either.
The only other thing is that i cant see how the bearing in the p/s tensioner going would make the belt jump on the p/s pulley only
as you can see in the pic, no.3 is the p/s pulley and the blank pulley at its 7 o'clock is the p/s tensioer. Either way there is a pulley between the tensioner and p/s pulley, so how would it be possible for a bummed p/s tensioner to cause the belt to jump on the p/s pulley, would it not jump on no.2 or 4 first???
Also, does anyone no if mechanics have any kind of tool of process where they can see if a pulley or belt is out line. Like if i handed the car over to say ultra tune do u think they would have a better chance of finding something wrong then i would... or would they just start replaceing stuff and charging me labour?
Btw i have checked all the pullies and brackets i can, and haven’t found anything suss
If anyone can shed some light on any of this please do
