suspect transmission
muchacho32
5 Speed Tip Problem...
Post by muchacho32 »
Hi guys just hoping you might be able to help me out a bit :D im having a few issues with my 5 speed Tip box over the past week. the car is currently with a mechanic who tells me something "major" has gone wrong inside the box... the car was fine up until last week when driving back from work and I was pulling away at the lights and the car seemed to "jump" forward (almost like a stall) then began making this grinding noise at the front left, like something metal was being dragged along the road while what felt like it was getting small moments of drive then nothing but grinding noises. I pulled over and found drops of oil following me I had a look under the car and couldnt see anything apart from a fair amount of oil sitting on the bottom of the transmission so I got back in the car (now about 15 minutes later) and as I pulled away the problems seemed to be going away as the car seemed to be warming up :? I took the car for a run down some road on the way home and although there was a light noise the clunky loss of drive problem seemed to be going away??? it drove fine to the mechanics apart from reversing out of the drive where the car came to a clunky stop (still engine running) but I gave it a bit more pedal and all was well... I was told later something major has gone in the box but the mechanic doesnt want to open it up unless he has some kinda backup.... but apparantly 5 speed tips arnt too easy to come by :roll: so im a bit lost... the mechanic doesnt want to open up the box mainly because he doesnt want the car sitting there for six months if he cant get the parts, but he seems to be under the impression the box is completely shot but cant really tell what exactly is wrong inside... I spoke to dstocks down here and we both agreed it was a bit weird the problem seemed to go away as the car warmed up, if it was something major had blown itself to pieces as the mechanic put, you think it would be around all the time :?... any help is appriciated guys :)
Fulltiltorgasm
Post by Fulltiltorgasm »
sounds like what has just been happenin to mine, however my cars symptoms werent so bad, i didnt have loss of oil or scraping sounds, however it would sorta stall just as u described, and slighty clunky and wierdly it would run ok after warming up lol, my car is a 97 GPX, and in speakin with the mechanical engineer, whos fixing the trans, he said that the facelift 5 spd gearbox, has been known to have occasional problems, apparently the box is a similiar but smaller magna box, i have only done 80000kms so its unusal for a box to go at that stage. so at this stage im waitin to here back from him, he had a hunch it was the pump seal ??? something like that. the guy explained it that basically the pump seal wears so therfore the pressure is not being fully applied as the first gear is situated next to the pump seal housing it means the first gear will struggle but after that the other gears should work close to normal.
btw, it mite be an idea to change the trans oil, thats what my mechanic did and in doing so he found 2 small shards of metal :( , if the box is gettin chewed up there will be metal shards evident when u change the oil.
muchacho32
Thanks for the reply fulltilt :) yeah i think i might suggest that to him. and the pump seal sounds pretty much right on the money :) ive only done 88000kms in mine and just had the transmission serviced about 3 months ago! its a 98' GPvR all the best with yours, let me know how it goes :D
Fulltiltorgasm
yeah finally got it sorted, it was 2 very small metal rods, broken in the planatary gears, being a rare 5spd there were no available parts in australia and the guy had all the 4sp parts in the world but couldnt swap cos of the electric sensors dont match and the computer would shut down. so the transmission place managed to get in contact with a guy who gets parts striaght from jap, as it seems mitsibishi australia dont supply import parts?? through thier dealership network. so finally got the part and should be here in a couple of days, such a mission, if i had of had a 4spd would of taken 2 days and all done, as he had the gearbox out and open he checked all other parts including the pump seal and he said it was in unusually good condition, these are supposed to be the source of the problem most times.
muchacho32
good to hear yours is sorted :) mine well seems like my best option is the manual conversion :( went out today to have a look at the car after its been in the workshop for about 4 weeks now and after looking at the box it became pretty clear not even a rebuild was possible :cry: the planatary gears were chewed right down in some cases and like you say the 5spds are extremely hard to come by(even in japan, I was told) especially in my case for finding a complete box. but on a positive note ive managed to find some guys that are willing to do the conversion for me if I can source a manual half cut :) so best get saving!!! lol :P
Daz_FTO
Post by Daz_FTO »
Going through a difficult time with my 4sp tip. What would i be looking at for a ballpark figure for manual conversion? The mechanic i know is a mate... so labout costs would be on the lower side of average.
I am getting him to test the solenoids and do an oil change first before going to the next step.
nvr2low
Post by nvr2low »
well i am doin one atm and their is a lot of time just trying to find the parts or u can just buy a half cut and have everythng their
