Diagnosing a problem (exhaust???)
bushido
Post by bushido »
It definately does. I can also wheelspin on my semi slicks.
Where can I can a new fuel tank and a new fuel pump?
Fuel tank just get second hand, fuel pump you can get from alco or camskill (which is an uprated) im talking with them now to find out how much better it is over the stock pump. From memory the stock pump on FTO are pretty good anyway. But ill let you know how i go.
bushido
Post by bushido »
Thanks Simon
yano
Post by yano »
Just browsing through and came across this. See how much a second hand fuel tank will be but also get a quote as to how much it would be to get your current fuel tank sand blasted. Might work out cheaper/better/easier. Goodluck anyways
bushido
Post by bushido »
Thansk yano
Ok found some Walbro pumps about 130 bucks which is an awesome price considering you will not ever need to worry about fuel supply.
mr-charisma
Post by mr-charisma »
I8A4RE wrote:Ok found some Walbro pumps about 130 bucks which is an awesome price considering you will not ever need to worry about fuel supply.
Sweet as mate :) please share ;)
Why do you need a new fuel tank :scratch: If its got crap in it, then just pull it out & clean in it. I wouldn't bother with an uprated pump either, considering the stock unit only ever works at 60% capactiy at full throttle anyway. An uprated pump will just put unnesseccary back pressure on the FPR.
I think he said his tank was rusted out
@ Mr C, ebay for the pump.
Kace
Post by Kace »
bushido wrote:Got the car back. it is running fine now. Heres what they did.
Labour
Carry out initial inspection
Disgnose mis fire
R and R intake manifold
Test ignition system
Test fuel pump pressure and flow
R & R injectors for inspection
Clean fuel injectors
Replace fuel filter
Remove and inspect fuel tank sender
clean fuel pump filter and re fit Labour total $335
Parts
Mitsubishi fuel filter $38
Service injectors ($44 each) Parts total $302
Additional comments
Noted excessive rust/water in Fuel tank
Fuel pump output is on teh low side.
Also told me that the fuel filter has never been changed or cleaned. (no logbooks)
And also from their ultrasound inspection, the fucked up injector was only running at 20% from all the sediment buildup.
Hi there,
Do you have any details on the Service Injectors that you got installed. I have never heard of these before and can't find any links to them for replacement. Any chance you have Mitsi Part Numbers ?
Thanks a lot.
| Silver 95 GPX Manual with world's only FTO Roof Rack | Longest standing FTO owner in Ireland - 20 years MIVEC experience |
| Silver 09 Audi A5 | 2.0 TDI Quattro S-Line Special Edition |
bushido
Post by bushido »
sorry kace i dont have any information on them
