Its a bit more complicated than that. I'll try & explain with some piccies
Both the mivec & non mivec motor has the same number of cams, the same number of lobes on the cam, the same number of valves. The big difference is the rocker assemblies, distance between lobes, cam profiling, and the heads themselve are very different.
This is a Mivec head:
This is a non mivec head:
Note distance between the lobes on the Mivec cams versus the GR cams? Also not that on the mivec cams, both lobes sit between the cam mounting towers. Where as on the non-mivec, there is a cam lobe on either side of the tower.
What actually makes the difference between mivec & non mivec is the lifters. Here is a Mivec assembly. Note that at any one time, only 1 out of the 2 lobes is controlling both valves. During low rpm, the smaller of the lobes is depressing both valves at a time. When in mivec, the oil pressure system flicks 2 valves on either side of each head & forces oil in to open small spring loaded pistons out from the centre of the rocker gear - thus forcing the second half of the rocker gear to engage on the Mivec lobes & effectively making the low rpm part of the rocker gear unable to reach the non-mivec lobe.
The mivec hydraulic pin here that locks the 2 parts of the rocker arm together:
Now here is the non-mivec assembly. As mentioned above, on the mivec rockers, only 1 lobe controls 2 valves at a time, here you see 1 lobe controlling 1 valve. meaning that on any cylinder both of either inlet or exhaust valves are being controlled independantly by 1 cam lobe.
This is what makes the head designs so totally different. Its a completely different style of cam design & profiling. 1 style to actually have 2 options of cams to choose from, the other having completely independant (yet fixed as in no second cam option) valve per lobe control. And in being so different, everything around them that makes them work is also completetly different.
Further down the track, what might be interesting, is if someone took the profile of the Mivec cam lobe & ground it onto a billet GR cam....(bags not paying the $2k for the billet cams thou
