Brake Pad/Rotor upgrade suggestions?
FTO338
Post by FTO338 »
Ok boys!! i'm going 2 woop all your ass with my Playstation 2 ok!!!!! :twisted:
Jono
Post by Jono »
Just bought a full set of rb74's From raceBrakes in Witherill park
Cost
$160- Fronts
$145 Rears
Craig said a AP 4 piston Kit is 3200 including labour..
:o
jono
smorison
The Godfather
Post by smorison »
hey guys, i thought i should probably update you. its a bit early in the project but i'd hate you guys to waste money.
Unique have my car at the moment (well as usual) and apart from changing my suspension they are doing a brake upgrade kit. what is it?
well it is an adapter so you can upgrade your rotors and use the stock callipers.
I have done hundreds of km's of driving exercising my brakes and honestly there is no need for larger callipers. using larger rotors with RB74 pads will provide all the stoping (And head transfer) you need to get the car to do what it should be doing.
They have already completed several of these for other cars so the hard work is pretty much done its simply sizing up an adaptor.
GR's: you will need to upgrade to EVO/VR4/FTO callipers on the front as the adapter is being built around the MIVEC setup.
dannyboyau
Post by dannyboyau »
what size discs are you using Steve
smorison
The Godfather
Post by smorison »
got stock ones on at the moment, i'm not sure what size they built the templates for as its all off at a brake specailist getting measured and built.
I wasn't there when they did my car as i'm not 100% sure what they did.
btw guys just a little bit of trivia did you know that our setup is the same as EVO4/5 ....
d_stroy_r
Post by d_stroy_r »
what do u mean?
smorison
The Godfather
Post by smorison »
d_stroy_r wrote:what do u mean?
dannyboyau
smorison wrote: btw guys just a little bit of trivia did you know that our setup is the same as EVO4/5 ....
what set up more information please
dannyboyau
i am guessing but i think you would be using the 294 mm diameter rotors from the EVO IV GSR not the 320 mm diameter rotors from the EVO V GSR
d_stroy_r
Post by d_stroy_r »
i thught u meant "our set-up" as everyones fto.......sorry :?
How much is the set-up then?
