done some more work,
I managed to get the driver side of the driveshaft out, but still the passenger side impossible to take out. Just to much pressure.
So I left the bugger there, and will drop the gearbox with driveshaft on it.
removed the centermember bolts x 4 and g/box mount bolts on the member x 2
Check out the condition of the rear mount on centermember. Need to be rebuilt with polly.
removed the bell housing cover, 6 bolts
removed the drive plate, 4 bolts. Had to turn the engine to get to the bolts. Access is very limited, and very tight bolts.
Supported the engine with bottle jack, some wood in between to prevent any damage, and back up support with bricks.
Supported g/box with garage jack, some wood in between to prevent any damage
Removed all the other bolts connection g/box to the engine,
Removed the g/box top mount, Get this out of the place, otherwise there is not enough space to push the g/box away from engine, side ways.
After fiddling a bit, slowly dropped the g/box on to the ground, and get it out of under the car through the passenger wheel arce. Had to take of the arce plastic cover to open up some space
Tip g/box is a lot heavier then manual!!!
Here is the pics of bottle jack supporting the engine, bricks are the back up.
