DIY Day 14th of August.
- Gholdwayne
Re: DIY Day 14th of August.
whats the start time at your place btw bennoz?
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- SchumieFan
- aza013
- NSW Coordinator
As per last page
Oh and all members that have big jobs need to be there first thing in the morning as we don't want to start them to late in the day.
It's bad when you have to quote yourselfaza013 wrote:Kick off would be 09:00.
Agreed - might bring this onto this page in case people missed it.
Bennoz wrote:This is the list of things I'll be doing. Keep in mind I'll be able to help out with your other bits & pieces, but this will be my main mechanical priorities:AJ wrote:Ben, are you going to put it in to a can do/can't do pile?
2. FTO_GPvR- Short Shifter to be installed
4. Tippin - Samco power steering hose
6. eddiii - Window rattle
9. Rock_it - Adjust tappets
11. zuihoujueding - window rattle, front droplinks - How many & which engine mounts are we talking about?
12. FTO-Boy - Spark plugs, Change auto tranny oil, change suspension spring, droplinks, replace front brakes - I know you want to do swaybar as well, but thats super time consuming without a hoist. Is the existing one broken or you just upgrading?
13. Gholdwayne - Adjust tappets
Im also thinking, for those of you that have tappets, depending on how we go for time, I might just have to do the front bank (the easy to get to bank) and show you how its done, so you can do the rear bank at another time. Otherwise I'll be getting bogged down taking off intake manifold after intake manifold.
- SchumieFan
do them all in 1 job, you take off the fronts, ill take off the rears... then swap... per car... wont do mivecs though unless they have the screws
- KJ_bob
Might come along and help out, been ages since i've come along to a club event.
Hey aza what are the chances you could bring your headlight sander? Have wanted to do mine for ages but i just dont have the balls to attack my headlights with sandpaper when their a couple of hundred each to replace
Wouldn't mind trying to diagnose why my aircon button is stuck while im their too
and who wants to help me with my angel eyes
- KJ_bob
just kidding about the angel eyes... im still in counseling from last time
- aza013
- NSW Coordinator
Yep I can do your lightsKJ_bob wrote: Hey aza what are the chances you could bring your headlight sander? Have wanted to do mine for ages but i just dont have the balls to attack my headlights with sandpaper when their a couple of hundred each to replace
and as for the angel eyes
- FTO-BOY
yeah ben my front sway bar has snapped off on the driver side and its been like that for 1.5 years now. was going around a round about then heard a massive snap under.. main thing i wanna do -in order or priority- is sway bar, change to lowered spring, front brakes, spark plugs (atleast help with the rear bank - i can do the front at home) ... i can change the tranny oil myself at home. i was also planning on doing the droplinks but ran out of finances so ill do that later when my tax comes in.Bennoz wrote:This is the list of things I'll be doing. Keep in mind I'll be able to help out with your other bits & pieces, but this will be my main mechanical priorities:AJ wrote:Ben, are you going to put it in to a can do/can't do pile?
The sway bar itself or just the mounts?
I had a mount snap on my magna, which is a much more fiddly part, do you also have the metal brackets?
- FTO-BOY
Yeah the bar itself snapped... i've got a second hand bar for now..
Sounds like we may just have to do the swaybar then. Do you have droplinks for it? Because you need them to connect it.
And I think I got confused by some chingrish in there "change suspension spring".... I thought it was only 1. Doing all 4 is about 2 hours worth of work...
- Shane001
Can u do mine too?aza013 wrote:Yep I can do your lights![]()
Might try and pull em out tonight. Not sure what time I'll get there though... family...
Also do you need the spark plug spanner back yet or are you OK if I hang onto it for a month or so. I'll look at getting the engine out and start the freshen up towards the end of the month.
- FTO-BOY
I've got the old droplinks for now...Bennoz wrote:Sounds like we may just have to do the swaybar then. Do you have droplinks for it? Because you need them to connect it.
If we ran out of time then ben you can just guide me on how to take the springs out.
My main concern are the sway bar and spark plugs
Yep, no worries
FYIFTO-BOY wrote:If we ran out of time then ben you can just guide me on how to take the springs out.
viewtopic.php?f=23&t=8761
pretty straight forward, just a time sucker of a job.
Rears are easy to do, fronts are a bit more involved.
- aza013
- NSW Coordinator
Yep I can do yours as wellShane001 wrote:Can you do mine too?aza013 wrote:Yep I can do your lights![]()
And I think we will need the spark plug spaner, if you could bring that with you it would be great.
After that yep you can hang onto it for a bit untill you find one or finish with it.
- Gholdwayne
^^ Oh, by the way, since i would have my tappets adjusted, would the replacement of sparkplugs be easily done while the tappets are worked on ?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Can even do spark plugs without doing the tappets, spark plugs are a synch.
