Nvr2lows 6a13 conversATION WITH BEN ABOUT HIS CONVERSION
FTEvolution
Post by FTEvolution »
I am glad you are getting some progress at last mate. Get onto them and be harsh about a work log though.
What hourly rate are they charging you?
Please don't get screwed over fella...
Good luck :)
Smooth and sleepy
nvr2low
Post by nvr2low »
well i got all the centre console back toghter today.
i replaced a inner cv boot also damn they are messy to change haha. i replaced all the turbo lines with fuel line pipe then also changed the vaccum lines from the rear wastegate.
They didnt get time to cut the hole in the firewall for mr so i can put the clutch pedal in.
I ordered the fuel pump from england that ben gave me the link to.
i also made up the clutch line from the master cyclinder to the slave cylinder.
mr-charisma
Post by mr-charisma »
nvr2low wrote:well i got all the centre console back toghter today.
How long does it take to cut a hole in the firewall? 8O
I thought you weren't going to need to do any mods to the firewall with the new manifold Ben got made for you? or did you run across some unforeseen drama's?
nvr2low
Post by nvr2low »
mate for the clutch pedal you need to cut a hole for the clutch master cylinder to go through mate.
nvr2low wrote:mate for the clutch pedal you need to cut a hole for the clutch master cylinder to go through mate.
Shouldn't stop you from mounting the clutch pedal thou mate ;)
Its the clutch slave cylinder that goes in through the hole, not the pedal coming out of it.
:facepalm: do you actually read anything or just the last post :lol:
he is doing a manual conversion as well, hence the driling of the firewall
nvr2low
Post by nvr2low »
ben mate you have to cut the hole in the firewall and also 2 holes either side of the hole as the master cylinder bolts onto these 2 bolts mate.
mr-charisma
lol .. yes, knew of the manual conversion .. smartass
nvr2low
Post by nvr2low »
hey guys good news went out their today and my car is gonna be worked on next week. This means putting the clutch pedal in and customising that damn front wastegate. Then guess what they are going to dump the motor in and send it to the exhaust shop yay. The guy also received the wiring looms so I hope he finished them within 3 weeks and then airbag them back. Got my new steering wheel to put it and waitiing on fuel pump and sterio surrond.
nvr2low
Post by nvr2low »
ok update
Yes the motor is finally in the car yay. All I can say is bloody hell it is a tight fit even with the new rear manfiold. The turbo sits nicely in with all the metal brake lines.
I will have pics when I gt home
nvr2low
Post by nvr2low »
hey guys some pics
can somebody please help me out with the pics the rest wont work
koolio1234
Post by koolio1234 »
Nice work mate,
Must be a relief to see it coming together. Did you go with a single turbo or a twin?
nvr2low
Post by nvr2low »
yes mate I am over the moon the motor is in. I am going twin turbo setup mate. I am going to get the car sent to gt the y pipe made up on monday then will start putting all the piping back on. Starting to put it all back togther.
FTEvolution
Nice work mate, but that looks very close to the firewall. Are you sure there won't be fouling when the engine rocks?
Smooth and sleepy
mr-charisma
Had to fix up the pictures... hehe :facepalm: :lol:
nvr2low
Post by nvr2low »
thanks micheal mate.
well ftoeveloution mate i damn well hope not as it is the same manifold as bens mounted in the same spot
it was a very tight fit to get the whole motor in with the gearbox attached. i am happy it is in. they are going to see if the turbo is ok were it is sitting.
i am sending it to the exhaust shop next door monday for the y pipe to be made then get it back and start hooking all the lines and pipes back up.;
Good stuff!
Yeah its still a tight fit regardless. Apparently they made some minor bends into the pipes behind the rear turbo on mine. Nothing major, just pryed them back a bit.
nvr2low
Post by nvr2low »
yeah that is eactly what they told me ben. they are also going to change the way my powersterring line runs so it goes no were near the turbo and doesnt get cooked.
mr-charisma
np mate .. btw .. 'tis looking good
'tis a shame it's taken them this long to get to this stage, but I assume they've got all the piping work sorted & it should be easy enough to whack everything together now?
nvr2low
Post by nvr2low »
yh mate i got all the turbo piping sitting here waiting to go he just has to finish the final leg in the front wastegate he has cut it and mounted it in its final position.
i just have to hook up all the fuel lines, aircon lines and all that kinda stuff man.
