Bennoz 6A13 Conversion
- FTEvolution
I agree, even with factory ECU, these turbo's spool amazingly quick. I would be using the NOS for a top end hit, you should have full boost by ~2300 rpm or so.
How much boost you planning to run?
You are progressing very nicely mate, good to see.
Smooth and sleepy
Smooth and sleepy
- FTEvolution
Nice one!Bennoz wrote:Probably only about 12 pound on the street, but the beauty of that Haltech is that it gives me 'push button track day' seetings! Probably pound up to 14 or 15 for that
I was contemplating a new ECU for a while, especially with these fuel prices. It is another reason I was sticking with the tip box. In drive I would have a ~5k rev limit, factory boost and conservative fuel/ignition. Then knock the fucker into Tip mode and would have ~14 psi, 8k rev limit, and aggressive fuel and ignition.
Still contemplating that actually, because I reckon the fuel savings over a year or so would pay for the ECU and tuning. Keen as to see how you get on with yours.
Smooth and sleepy
Smooth and sleepy
- aza013
- NSW Coordinator
Tell him its all happening at the Envy stables. Im sure he knows Herman & Brent
Heaps done today, will update later. Including a DIY on how to change your fuel pump. Also had the intake manifold & a number of other pipes sent off for sand blasting, HPC coating & then powder coating in that intake pipe blue colour
And also mounting of thermo fans (that didn't want to fit) and FPR lines.
- aza013
- NSW Coordinator
Ran it inside the car. Through behind the back seat, then up along the side of the car. Pulled the kickplates off & pushed it down in there. Yeah, will be using a dist. board.MAD-FTO wrote:Where-abouts did you run the power cable from the boot to the engine bay?
And did you just use a distribution block for all the positive wires in the bay?
- yano
lol, stop spamming his thread...you have your own thread to ask bennoz questions...might wanna post here http://www.ftoaustralia.com/modules.php ... ic&t=16723nvr2low wrote:hey ben mate is that the same fuel pump you gave me the part number for mate.
Were can i order these like at autobahn or something like that mate.
your fuel pressure regulator looks sweet man how much did it set you back.
- mr-charisma
