Bjs turbo Version R fto
- bass_twitch
Re: Bjs turbo Version R fto
Pure class
Sorry can't help myself looking at those pics
- fto-007
You needed to delete "&feature=youtu.be"
Fixed
Fixed
fto-007 wrote:
- Kustom
Need to see it destroy an evo or something on the street, not a small taste of it revving (cant even hear the BOV
- Tippin
sweet looking setup
- fto-007
still have to put the 1000cc injectors in and a lot of little things need tidying up
when i get it tuned they will setup launch control, flat changes, traction control and dial the cams in
should sound good with 272/300 cams and massive amount of boost lol when its all finished and tuned ill put put more pic and vid up
- Supplanter
- fto-007
That's another little thing I have um work out its a tight squeeze! :-\
- Tippin
haha, i cant tell that well from the pics but maybe a 45degree bend off the turbo and a cone shaped pod might just fit in there
- aza013
- NSW Coordinator
Still loving it
now we want power charts
- bass_twitch
And a joyride.aza013 wrote:Still loving itnow we want power charts
And a drag night
-AJ (if he gets the thing working with the new alternator)
-Bennoz (With his 'street' tune)
-BJ.
Any others I'm missing?
Taz next yearbass_twitch wrote:And a joyride.aza013 wrote:Still loving itnow we want power charts
And a drag night
-BJ.
- spetz
Who is making the cams?
And are the internals going to be standard?
- fto-007
its the most you can modifie a 6a12....cams were made at rpw 272/300 degree with ajustiable cam gears, rods and cams were custom made at JE pistons, bored .40, heads ported and polished flowed 400hp @ 12psi, crank blue printed and ballanced, over sized bearings rod and big end, build to run 150hp NOS, +all the bolt on stuff
aiming for 300+ kw atw
$15 000 on internals
Sahin wrote:Taz next yearbass_twitch wrote:And a joyride.aza013 wrote:Still loving itnow we want power charts
And a drag night
-BJ.
Would be a good benchmark to test the stock motor against 007 - he has more power, i have AWD, a lot less weight and setup for track...
- spetz
Who did the head porting?
Should be really nice when completed and running
- fto-007
What car do you have being 4wd? I will strip the stereo and upgrade the brakes before I track it
