The FTOA Oil Thread
- zuihoujueding
Re: The FTOA Oil Thread
Came across this article and its a good read.
http://www.ihonlynorth.com/forums/oil-t ... r-oil.html
Just wondering if FTOs have flat tappets?
- payaya
I've tried everything and magnetec works best. I may try a 15w40 next and see what happens.zuihoujueding wrote:I was using the top of the line Shell Helix Ultra 5W-40 and for some reason, the engine is quite noisy, until i changed back to the usual Castrol Magetic 10W-40 and the noise has dropped down considerably.
Well, every engine behaves slightly differently so i guess its normal.
- zuihoujueding
for the current weather, it only make sense to go 0W/5W rather than going upwards to 15W.
- Gholdwayne
UAS told me that magnatec is shaithouse
The mechanic who worked on my car said that oils like ELF, Mobil, and some other brands i forgot, were good.
^Yeah, i plan on using the mobil 5w30 i have in my garage for this winter soon...zuihoujueding wrote:for the current weather, it only make sense to go 0W/5W rather than going upwards to 15W.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
My Brother ran his civic on the same oil for 80,000k's with the same oil filter (retart)
- -Nighthawk-
So what's the final verdict after years of testing? haha.
I've been running Mobil 1 in my car even since I got it over 2 years ago and it seems to be pretty good. It's 0W-30W fully synthetic. Only thing is it's a bit pricy.
What is the current recommended oil to use now? (I've read the entire thread)
- shadowarrior
- Tightarse
Looking to pickup the Motul 300v for the Manual GPX. Question is, keeping QLD summer in mind, should I go for 5w30 or 10w40?
Also going to pick up a Purolator PureOne oil filter. I found the following part numbers from Dwayne's website:
MD332687
MD365876
MD360935
MD135737
Which one is for the Manual GPX? And does Autobarn/Supercheap stock them? (Am in G.C).
MD332687
MD365876
MD360935
MD135737
Been running Castrol edge 5-30 full synthetic for a few months now, and i must say my engine is absolutely loving it
Bought it on special to give it a whirl (like 40 bucks from 100) and its definitely doing what it's supposed to. Came down from 15-40 and haven't heard anything from tappets or nothing, such a smoother feel.
Got the thumbs up from me =)
Doubled that with a standard ryco filter too
- aza013
- NSW Coordinator
Agree ^^^^^Taz wrote:Been running Castrol edge 5-30 full synthetic for a few months now, and i must say my engine is absolutely loving it![]()
Castrol edge 5w/30 full sin is the only one I use.
- shadowarrior
- Tightarse
Hmmm, Castrol. I use Motul5100 (everyday use) and Motul7100 (trackdays) on my bikes (and I absolutely love them!!), so was leaning towards the Motul.
Are you guys around QLD? 5w30 looks like a good choice. But being summer I was thinking of going 10w40.
Anybody know about the part number for the oil filter?
- zuihoujueding
im having terrible oil consumption when using 5W-30. maybe its just my own engine problem. been googling and there can be two main faults: worn pistons or worn valve seals, or both.
How can i check those faults?
Did compression test a year ago and it was ok.
btw, oil filter is same with most other mitsubishi cars. Z411
fuel filter is Z441
fuel filter is Z441
- Shane001
Castrol edge 5w/30 in the racecar too
Motul 300V is good sh*t though, but very expensive.
sh*t looks like i finally picked the right one for a change
Aza and shane's seal of approval is more than enough for me
- zuihoujueding
Isn't hard driving requires higher rating? like 50-60?
5W-30 are deemed to be fuel conserving oils.
Ofcos the quality of oil plays a huge part but how about the rating in this case?
- Shane001
Yes and no. For an engine designed to use a 5W30, u wouldn't want to run something as heavy as a 50 or 60. If you were running a turbo with much higher boost than normal, putting out much higher power figures, you would probably want to run a little bit heavier, simply due to the heat and increased stress within the engine, but if you're running a quality synthetic u generally want to stick close to spec.zuihoujueding wrote:Isn't hard driving requires higher rating? like 50-60?
Engine Oil has one of the highest levels of misinformation, misunderstanding and general associated bullshit of just about any other automotive component out there, just take Penrites +10 campaign as a good example
Edit: I should add to that, extremely confusing
f**king marketing departments = idiots
- shadowarrior
- Tightarse
anybody from QLD (or GC) can tell me where to buy Purolator filters and Redline/Motul 300v oil from?
Supercheap doesn't stock them, Autobarn only has 2l Motul 300vs, no one has Purolator filters.
- phunkydude
For redline, try autoone stores (not 100% sure). There's one in beaudesert. They might stock purolator filters as well.
Give them a call before you go.
http://www.autoone.com.au/StoreLocator/ ... 1b9d497ee5
Or, best yet,
http://www.performancelub.com/Redline%20pricelist.htm
For filters, pay a bit more and get the k&n hp1010 oil filter from autobarn. It's about 22 bux.
Or, best yet,
- shadowarrior
- Tightarse
k&n filter it is. if not the redline, I might pick up Motul 300v 5w30 then (5w30 good for qld summers?) any idea how much does the 5l jar of motul 300v 5w30 cost? (think i can order that from Autobarn)phunkydude wrote:For redline, try autoone stores (not 100% sure). There's one in beaudesert. They might stock purolator filters as well.
Or, best yet,
- phunkydude
Qld summer isn't that hot really. Mostly hovering around 30 degrees on daytime and does cools down at night.
What's your current mileage/odo? If it's high then stick to 10w-40.
Thinner/lighter oils tend to sips through your gasket/seals, causing oil leak if the gasket/seals not doing their job well enough as they ages.
5l 300v would cost you somewhere around 150.
- zuihoujueding
i got the purolators from autoone from Newcastle. they had a dozen left and i took all of it.
