Lawso's project thread
- Kustom
Re: Lawso's project thread
Someone offers enough they can buy my car already doneKustom_FTO wrote:I vote gr-t
- Kustom
Id really like to see ben's dick that is why I am driving done to sydney
I thought as muchKustom_FTO wrote:Id really like to see ben's dick that is why I am driving done to sydney
- Kustom
Kustom_FTO wrote:Your thilly.
Meanwhile Ben.... I dunno..
Your choice what you want the car to do, but mmmm *shrug*
Could give you a lot of reasons not to rebuild your motor... especially if you still want to go turbo later.
Well, I spose this is my thread now... better update it
Car is currently round at mine for a major 'fix everything' service.
Apart from the hideous body work & interior abominations, the car is in not tooooo bad a shape mechanically.
Everyone thought it had a blown head gasket, but it doesn't. Just a couple of shot rubber pipes.
Brakes are farked too, but I'll strip them down & sort it.
So I stripped it down this arvo, couple of pics as such.
As far as im concerned, this is what it needs:
- timing belt
- associated timing belt tensioner & idler
- Full set of cam seals, both ends & crank main seal (timing belt end)
- rocker & spark plug gaskets
- hydraulic tappets reco
- radiator & heater hose replacement
- seal up thermostat housing properly (goo)
- replace coolant refill tower with fucked overflow (rusted) pipe and goo
- lower engine mounts (super farked)
- thorough clean of throttle body & plenum
- fix seized handbrake cable, reco all calipers, bleed system
- replace fuel filter
On top of that, am gonna do a few performance mods
- new intake pipe (GR style) with Monza pipe & MAF relocation & pod filter
- 'track day' cat lol
- new collector pipe (Y pipe) connecting manifolds to cat back
Apart from that, its not in that bad a nick (for a 3 grand FTO)
Here's the lower engine mounts. There are 2 major problems with this, see if you can pick what they are - 1 is quite obvious LOL
I'll give a 6 pack to whoever can pick both issues....
As she lies tonight
- timing belt
As she lies tonight
- SchumieFan
isnt that the wrong fkn mount on the left???
anyway
your keen buddy... quittin cuggys then startin that sh*t!
i hope he's paying you well!
anyway
- Kustom
- aza013
- NSW Coordinator
They should be solid mounts
Or am I mixing them up with other mounts/ bushes
- koolio1234
I think your right there azaaza013 wrote:They should be solid mounts
they should be these mounts
Nope! Its a tip, hence the non solid mounts.
But that picture above has the hint in it that you need.....................
- aza013
- NSW Coordinator
Mounted back to front
- koolio1234
The left mount is on the wrong way around, which is not the way it was designed to efficiently absorb the torque twist?Bennoz wrote:Nope! Its a tip, hence the non solid mounts.
- aza013
- NSW Coordinator
So I win
Well not really as I did not say both of them
3 beers for you, 3 to Koolio
- Kustom
GTFO mooch!
- Kustom
