I8A4RE Turbo thread: Questions and Comments
Is that with a ECU install? Which one did you get emanage?
Yeah he was impressed with FTO's, he said normally looking 3-5kw gain on a NA car.
- mr-charisma
Around $750 for the emanage and $840 for the install and tune but that was with some minor work like replacing spark plugs.mr c wrote:How much did it cost you all up for the e-manage + install & tune?
I was going to do it in two stages as quoted in my first post but becaus of the price of tuning and the fact that i want to do this as cheap as possible without cutting corners ill do it all in one hit now. I am going to install the most that i can, most of the piping, intercooler, oil return line, etc. Im pretty sure if i ask the local exhaust guy he will let me use his welding gear. What im thinking will be hard to do myself, is make up some sort of bracket to mount the turbo.ethix wrote:When you get your next tune done will you be getting it done when you in stall cooler/piping/injectors/fuel pump/ etc all at once?
and are you installing all the parts your self or most?
Havent really been hunting lately, had a few other things going on, the only things now i really need is a RRFPR and some guages really
- khunjeng
why would he do 2 more tunes?, should be done he has no other mods so its a basic AFR change..infact should have only taken about 1hr on the dyno.eThix wrote:Yeah, i thought you were going to get 2 more tunes (which will cost heaps)
if you lived in nsw's then you could probably get my brother inlaw to do the welding but that shouldn't matter if you are aloud to use a welder at an exhaust shop
BTW hows the parts hunting going?
I used the emanage blue in mine...was about 110 kw atw with stock extractors and tip...
best power upgrade for your FTO = manual!
im too old for manuals and i cant afford a porsche so ill be sticking with tip but thanks for the info
No idea thats why i was asking......khunjeng wrote:why would he do 2 more tunes?, should be done he has no other mods so its a basic AFR change..infact should have only taken about 1hr on the dyno.eThix wrote:Yeah, i thought you were going to get 2 more tunes (which will cost heaps)
interested in boost gauge and maybe turbo timer. but i want white face dials or smokey face but if super cheap i may be swayed. Get me pics and prices
Thoughts?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0021361611
Do you think it would fit in the clock or voltmeter position.
White face and fits in the voltmeter/ clock position.....very interested
- yano
Are you after any style in particular?? 2inch gauges will fit. Confirmed this at a store
These are cheap and will do the job for you. Look decent too....
http://cgi.ebay.com.au/4-x-New-Option-J ... dZViewItem
thanks guys but yeah im after WHITE FACE only as i want it to go with the white guages i have already.
So 2" will definitly fit eh
