DIY: How to replace your dash bulbs with LEDs
mxysxy
Post by mxysxy »
What does this T10 means?
I just searched the ultraleds web side, nothing come out.
Is that means “10 mm ledsâ€
Ther
Post by Ther »
yes Max it means 10mm led...
check:
http://www.digielite.com.au/ for the 4 led T10/T8 they are quite bright. i used them to replace the 3A brand ones i had.
http://www.ledshoponline.com/automotive ... e_bulb.htm
can get the wide angle t5....but i also used the SPL brand t5 from motorquipe..quite bright, good for the cigarette lighter and also the aircon ( not main screen) you get 5 for 12 bucks... :wink:
Ther
Post by Ther »
Breza wrote:
Next, I am working on new globes for the mirror controls, electric arial and fog light switches. anyone replaced these yet? I assume they are just a 3mm bulb?
Cheers
Chris
I pulled the antenna switch apart and the globes for those are tiny...not sure bout the size... :(
Wraith
Post by Wraith »
There's lights meant to be in areal switch and the fog light switch? Damn!!!! they never worked in my car... how's it come apart? I had a look when I had the consol out to replace the globes in the speedo but couldn't see a way to get them further arpart...... Any suggestions? Also did you figure out the size of the globes in them?
What's the best LED's to use in the aircon display? the T10 wide angle?
working my way through it slowly.
thanks heaps
Andre'
Ther
Post by Ther »
Wraith wrote:There's lights meant to be in areal switch and the fog light switch? Damn!!!! they never worked in my car... how's it come apart? I had a look when I had the consol out to replace the globes in the speedo but couldn't see a way to get them further arpart...... Any suggestions?
what you need to do is open the case with a small flat head screwdriver, it has a little "latch" on the side
Wraith wrote:Also did you figure out the size of the globes in them?
nope i'm not sure..maybe a 3 mm led...
Wraith wrote:What's the best LED's to use in the aircon display? the T10 wide angle?
thanks heaps
Andre'
Aircon , a 2 t10 for the screen part and 2 t5 for the sides.
where abouts are you located?
Wraith
Post by Wraith »
Thanks Ther.
Will have a look at it soon. going to source some more LED's for the rest first and then move onto the lights that neer worked in the first place :)
am just north of Melb :)
Anyone got any pics of what their dash's look like with LED's? I've gone for Red... just coz everyone seems to be going Blue an green is a little to "old school" for my taste. Red makes the needles stand out ever more so as well :)
Ther
Post by Ther »
<img src="http://members.optusnet.com.au/~ccisterna/mypic9.jpg"> main dials..
<img src="http://members.optusnet.com.au/~ccisterna/mypic10.jpg"> clock and voltmeter
what you can't see is that all needles have a really bright red/purplish pink color....
onnzo
Post by onnzo »
Hey Ther,
You know how you only replaced 4 of the 5 bulbs, yours still looks blue all around!
Mine is white on the temp section and half the speedo!
Mike
Ther
Post by Ther »
onnzo wrote:Hey Ther,
Mike
Hey Mike
It must be because my LED are quite bright and they distribute all around the dash, i still left one normal bulb for the gears part although you can't see it in this pic but you can see how the FTO part still red.
the bulb that i left normal is the one just behind the PRND area. If your speedo and the temp are are white , then it must be that you replaced the wrong bulb, try putting and led in that area and leaving a normarl bulb near the gear side.
<img src="http://members.optusnet.com.au/~ccisterna/mypic11.JPG">
TimmyD
Post by TimmyD »
Hey
Are these the right T5 LED's we use?
Cheers
Tim
Ther
Post by Ther »
yeah mate those are the t5's but i don't know how bright the narva ones are..i guess you need to test them.
Also those look like the narrow angle ones, wide angle have a squarish top.
CSV
Post by CSV »
Hey ruchi, just wondering whether you were still going to do those kits later this year? I would love to pick up a set. :D
I don't like signatures, you are always expected to say something funny or interesting. So I'm not doing one...:)
[img]http://img.photobucket.com/albums/v308/csv/sig.gif[/img]
Digital_Import
Post by Digital_Import »
if u want a nice even spread of light a trick is to use a file and sandpaper. file the top of the LED flat then use a fine sand paper to make all the glass sort of misty.
CSV wrote:Hey ruchi, just wondering whether you were still going to do those kits later this year? I would love to pick up a set. :D
I don't think ruchi visits this site anymore :(
fto617
Post by fto617 »
hey if i bought some LEDS from jaycar
do i need to have resistors as it doesnt come with it
what will happen if i dont have resistors?thanks!
ph3var
Post by ph3var »
The Jaycar ones are 3v and without resistors they will just blow and then there will be no light :P
Custom purple 1995 GPX manual
fto_chris
Post by fto_chris »
has anyone ever done the ignition ring light?
or can it not be done??
Breza
Post by Breza »
Yep,
You have to puul the plastic casing off the steering column, you can substitute the stadard globe with a T5 ultra bright LED. Its just a similar set up to the cigarette lighter.
Also, the aerial and fog light switches are T3 LED's, don't think they are 12v, I tried a T5 3v LED but it was too big to get the casing back together but it didn't blow when I tested it.
Anyone know how to get the mirror switch apart? I can only get the black bits off the back but can access the PCB. Next project is the window switch on the driver side door.
Cheers
Chris
Lenny
Post by Lenny »
Don't suppose anyone has a parts listing for all the led's requiered??
Would like to just plug and play these baby's....
Look on page one of this thread :wink:
