My other project coming to an end .... Sort of
Re: My other project coming to an end .... Sort of
Not much more to report ... Just been paying off suppliers... :( Really hate that part...
Newest purchase is this ...
So car is going to have the ability to run as AWD or RWD depending on the mood I am in ... Part is meant to be rated for 800hp ... So I should blow the drivetrain before I kill the gearbox... Well in theory anyway ..
#driftlyf
Seems weird that just a small component makes changes like that! Don't want to ask what that set you back! :lol:
Yeah, need to slightly mod the front drive shafts as well apparently ..
Gotta get Ricol to check it all out, and make sure it is not too much effort. But yeah, "Made of Billet Chromoly steel , this product has been reliably used to transmit 400 wheel hp to the ground on drifting EVO's."
Could make a copy of it, on the cheap, by welding up and playing with an existing coupling ... But would not be sure on how stable it would be under load... So given how much this car owes me, best to play it safe...
Next comes #stance... Blahahah ...
http://s171.photobucket.com/user/rock_i ... 3.mp4.html
So 249kw atw.. (20psi)... Could run higher boost but happy with it there.. Most efficient range for the turbo on it, and should not put too much stress on other parts.. So no breaking sh*t..
Will get it back, drive it, and see how it goess..
Injectors still have heaps more left to give, so really comes down to what turbo, where I went the power etc.
That'll do nicely
Needs moar
Daniel2019 wrote:Needs moar
Lol!
Needs to be driven..
Lol!
This
How's the swift goin?
destinationtoby wrote:
Lol!
This
Swift is going good man .. Has a few battle scars... So will fix those up after the wife has been driving for a while. Still have front + rear extensions to add to complete the kit...
Great car to drive, and very comfortable... Have almost put 60,000 on the clock... 8O
Lol!
This
Yeah but they're a timing chain, not a belt. No need for major service till 160k :cheers:
Bennoz wrote: Yeah but they're a timing chain, not a belt. No need for major service till 160k :cheers:
Mad... :)
Hey Mr Prez.. Looking at FEDERAL 595 RSR's ... $149.5ea ... Just deciding if need 225 or 215's...
Mad... :)
Always go bigger :lol:
Seen the new 595 RS-RR?
http://www.federaltire.com/en/products_ ... tail_sn=36
Bennoz wrote: Always go bigger :lol:
Yeah, the 215's just clear on the rear... So may get more scrubbage than I bargain for at 225...
That new design looks hot!!! 8O
But dread to know how much they will go for... Have got the 215's down to $137.50ea ... :)
So will prolly grab em now...
Pick up is tomorrow... 8)
3rd gear? :(D):
sh*t tyres on the car, made 4th unbearable and pretty dangerous given you will hit higher speeds... The shakes and ride was terrible, due to the tyres being so hard and out of shape... They were about 8 years old, and mostly spent more time sitting round than anything... They were that old, they were on my Sonata... 8O
New rubber is on, and none of the shakes exist that it use to have, but these came after I saw how bad the car was driving.
Tuning wise (and power wise) depending on the dyno set up, and the load applied results should be about the same ..
I want to do a run and see how it goes on an AWD dyno, and see how much of the power goes to all wheels, instead of being lost to the rear, and whatever the coupling and box absorb from the front...
Am loving driving this thing to work ...
Don't want to go back to the Swift ... Hehehehe...
But I think the neighbours are gonna start hating soon .. Have adjusted my hours so I leave at 7am for work, instead of what the usual of 6:30 - 6:45am ...
That's a face that means business! Can just imagine this thing carving up a hill climb...
Should get some retrofit projectors and black the headlights!
bjk wrote:That's a face that means business! Can just imagine this thing carving up a hill climb...
Have seen some on ebay .. But like $500 ...
Better things to spend on than that ... But may look at it at a later date...
Yeah that's a bit much.
