My driving lights (fog lights) have suddenly stopped working. When I press the switch, nothing happens, no lights at the front and no dash lights. I seem to remember a problem with a switch burning out being a common problem, is this likely to be that problem or is that something else? Anyone got any ideas?
Cheers,
Gavin
Driving Lights Not Working
- HiRAEdd
- kazbah
- National Secretary
Switch
Its likely the switch - common weakness. Check the back of it and see if there are burn marks on it.
- payaya
- payaya
Ive relayed mine but totally bypassed the switched. I couldnt be stuffed figuring out the pin outs on the switched so i installed another switch.
I did mine the long way but im guessing easier at the time.
Fused use a postive to both fogs relayed the connections then installed a switch in my car to trigger it.
Do a search on relays and it gives you an understanding of how they work. From that its easy to relay up the system.
- FtoSam
