gauges
ethan
gauges
Post by ethan »
Does anyone knows how to install oil psi and vacuum to a GR?
<head>
<title>eThAn's HOmE</title></head>
<body>
<img src="http://i13.photobucket.com/albums/a283/Beeni406/05080100317.gif" width="176" height="144"/>
</body>
</html>
Boris
Post by Boris »
I would probably reccoment googling for more details, the vacuum should be very simple, just put a T into the vacuum line in the fto vacuum hose. (I have a vacuum gauge)
The oil preassure i would image would be the same as the oil temperature? The cleanest way would be to browse through th group buys section and look for the oil adapter group buy...
bigpitty1
Post by bigpitty1 »
With the oil pressure gauge you will need a sender unit, on some kits they have a oil filter adapter and some bolt on somewhere on the engine.
khunjeng
Post by khunjeng »
bigpitty1 wrote:With the oil pressure gauge you will need a sender unit, on some kits they have a oil filter adapter and some bolt on somewhere on the engine.
yep...usuall the hardest part is running the cables back through the firewall...the sender install is usually ok.
