oil, transmission, power steering coolers
- spetz
I have some questions about coolers
So far I am gonna get a 19 row oil cooler
Also, I had a power steering cooler but it rubbed on the mesh of the bodykit and made a hole in it. Now it has no cooler. The question for this is can I add a cooler and have the power steering fluid running through it continuously? Will it because problems with fluid being too cold (like for example oil can't be too cold)
And for manual transmission, can I add a transmission cooler?
- Nacho
If you have noisy tappets i'd take care when driving first thing in the morning with an oil cooler. May want to warm your car up while not moving until the noise disappears and the oil is flowing normally.
They're great for track days, and turbos. But for street use they're a stupid thing to purchase.
[img]http://members.iinet.net.au/~viper39/carbw.jpg[/img]
- smorison
- The Godfather
- spetz
With the oil cooler, it wont be flowing oil through it all the time, only once the oil reaches a certain temperature (say about 95 deg C) and then it will start flowing through it until it goes down to say 85 deg C and stop flowing through it.
All coolers would be installed in the front somehow.
And it's not that I know I need them or anything, but just to minimise wear and tear and to have peace of mind. I mean I had a power steering cooler so at the least I am guessing I need to replace it. My question is though can the power steering fluid be too cold? Same like engine oil can be too cold for optimum protection?
As far as bonnet vents go, I don't want one but I have HPC coated extractors to help under bonnet temps
- smorison
- The Godfather
power steering fluid is very similar to transmission fluid (when using fully synthetic) ... you can actually use transmission fluid in your power steering if you really really want to....Bennoz wrote:Most power steering fluid will operate porperly anywhere in the range of -5 degrees C to +150 degrees C. It is a very hardy fluid.
just a bit of trivia
- spetz
Yeah I had to use ATF when I was driving an found out I had no power steering fluid
Although power steering fluid might work from -5 to 150 degrees, what about wear and tear?
I mean, an engine can run on oil which is cold and which is hot, but ideally for minimum wear and tear in the 80 to 90 degree range.
So what is the ideal range of power steering fluid?
I am guessing no one really has a clue?
