hey people
i really desperately need... them little squirting things on the bonnets so you can clean the windscreen...
where can i get them from?
i prefer the stock ones
WTB- have no idea whats it called...
- ANBU_fto
...groOl...
08 Evolution X - White
97 Gpx Fto - Racing Red
- Panelhouse
- ahew
they're called windscreen washers.
if you're missing them then there should be plenty of places that sell replaceable washers... even the led ones if you really like rice. ahem.
if they're not squirting out water, just pop them out and give them a good clean... i had something stuck in mine that stopped it from squirting
Washers
Just had a thought on this. If these are not working (if theyre just missing ignore rest of post) it could be a number of things. Before you buy, check that the washer motors are actually working and the washers themselves are not blocked. No point replacing the washers if the problem is further back. To test, unplug the hoses off the back of them and hit the button on the indicator stalk. If you get water, they are working and if you dont, the problem is either electrical (fuse, switch etc), or the motors.
- Panelhouse
OK
......Umm...... OK Then!!!!......
Dont you hate that
Dont you hate that.
You can hold onto bits and pieces for years and the day you need them is generally less than a week after they have been thrown away.
It never fails to annoy me.......
