My New Homemade Gadget
- BuCkEt
The reason why I used caliper paint is purely because thats what I had, and didnt want to spent more money, nothing to the with heat.SchumieFan wrote:erm... u know how u buy engine paint etc... its resistant to heat right?
why not just paint your intake pipe with that? of is this a stupid idea?
You can use any paint for this application as the pipe is facing the outside temperature.
- BuCkEt
Barfy, if you check out DStocks thread about his CAI you can see how the original piping goes up towards the top of the radiator.
All you would need to do is remove this stock piping and run tubing down towards the ground. Boris has also done a DIY thread on this. In fact I'm willing to gather that with your VS front bar things will be significantly easier.
- SchumieFan
yeah thats all good, i wuda done the same... im just asking whether it would be a good idea to use engine paint because of its heat resistant factors.... bareing in mind u have to bake the paint after applicationmxysxy wrote:The reason why I used caliper paint is purely because thats what I had, and didnt want to spent more money, nothing to the with heat.SchumieFan wrote:erm... u know how u buy engine paint etc... its resistant to heat right?
As far as I know, caliper paint is more heat absorbent then engine paint.
Never used engine paint before though.
And it wasnt saying anything on the can about baking the paint afterwards. Too lazy to do it anyways....
Ohhhhhh,
Just remembered now!
I did baked my battery clamp after painting with caliper paint.
It boubled up, obviously didnt do it properly.
Ohhhhhh,
Ok i looked at boris's DIY piping although im thinking it will restrict the radiatior of to much air.... Just the other thing im thinking about is the hose that goes into the box itself is that easy to replace and to attach to the stock piping ??
What im thinking of doing is what bucket said but need to know about the piping that comes into the box ...
- BuCkEt
