Hi,
I'm new here but have an issue with my 1996 FTO GR DOHC. The car has been in storage for a couple of years but is now out and running again. However, it runs fine for 15 mins or so then loses power and starts pinging really badly and eventually dies, leave it to cool down and the process can be repeated. Starts, drives fine for 1 -20 mins and then dies.
Replaced all HT leads spark plugs and one faulty coil pack, also checked Cat Converter (clean as a whistle), no error codes when checking ECU....
Any Ideas?
Car dies after 15 mins of operation
Juvet
- Supplanter
Juvet
Re: Car dies after 15 mins of operation
Hi Supplanter,
Thanks, but I have already replaced the fuel filter..... no difference.*
*also, not a mechanic
Juvet
Thought I would update this post to help anybody out having similar issues.
After months of faultfinding, downloading electrical drawings etc. I traced this fault to the IFS (Ignition Failure Sensor). As this is mounted on the coolant thermostat housing, as soon as it got hot it would fail
and cut the fuel pump off, let the engine go cold the sensor would start working again and the cycle repeated until the sensor failed completely.
