DIY changing front sway bar bushes
vipfto
Post by vipfto »
You will need
17mm sockect with extention and 1/2inch drive ratchet
12mm ring spanner (ratchet spanner if you can will halve the time)
jack stands
pry bar or big screwdriver
17mm ring spanner
new sway bar bushes
1. Jack up car and place jack stands under sill panels (you cant have any weight on the sub frame or lower control arms)
2. remove wheel and sway bar link pin connected to strut as shown
3. Undo the 3 17mm bolts through subrame as shown (both sides)
4. This allows you to drop subframe just enough as to allow spanner in to undo 12mm bolt that holds down metal bracket keeping bush in place
5. remove old bush and replace with new (remembering to grease new bushes with grease that should be supplied)
6. Then bolt up subframe you may need to use pry bar or lever to help line up holes for bolts and bolt back up link pins and job done :D
this took me about an hr, but without a ratchet spanner or a very good knowledge of car it may take longer, only difficult part is undoing bush bracket bolt especially when on your back under car with no hoist
ther is no need to remove ball joints or gearbox crossmember or totally remove subframe its just needs to be dropped slightly thats all
Re: DIY changing front sway bar bushes
Nice one! At long last we have a front swaybar bush DIY :)
Fixed the piccies for ya too Tim ;)
vipfto
Post by vipfto »
Bennoz wrote:Nice one! At long last we have a front swaybar bush DIY :)
thank you I maybe real good with cars but useless with computers :lol:
Yeah mate join the club, I can use one but thats about it.
Would this amount of droppage of the subframe be enough to put a new swaybar in?
silverGPX wrote:Would this amount of droppage of the subframe be enough to put a new swaybar in?
Thats a good question. Im sure dstocks will be along shortly to tell you...
lol thanks ben
Tippin
Post by Tippin »
very nice DIY, i hope i dont ever need to replace mine again :lol:
how often should the poly ones be replaced anyway?
mindxcycle
Post by mindxcycle »
Would it be possible if the pictures could be updated? I've been struggling with a few posts due to the images dissapearing.
Thank you
