Rear Brembos
vanadinite
Rear Brembos
Post by vanadinite »
Found this link post on the mirage forums on installing the rear brembos onto a mirage/colt without brackets etc and because the fto setup is the same it should work in theory. The mirage forums requires login so for those who aren't members here it is.
"The reason for this post is that i've had a couple of people ask how i fitted the Brembo calipers to my Hatchback colt. I will start off with a list of parts that you will need and then post up a how to fit guide, which most of it will be copied from another forum that i am a member of. As far as i'm aware, there are only 2 colts in the uk that have this setup and myself being one of them :D Here is the parts that you will need:
> Evo 5-9 Brembo calipers
> Evo 4/5/6 Master cylinder & Servo. Evo 5/6 is bigger.
> Evo 4 front lower arms/ wishbones
> Evo 4 Anti Roll bar
> Evo 4 Drop Links
> Evo 4 Hubs (5 stud)
> Fto Rear trailing arms
> Fto Rear Hubs. Dont use the evo ones as theyre designed for 4wd
> Galant 1996 onwards (Non-VR4 model) Handbrake drums/mechanism (complete)
> Standard Colt handbrake cables
> Hel braided brake hoses
>Evo 5-9 brakes pads & discs
I also upgraded all the bushes on mine to polybushes but that should be self explanitry if you too want to upgrade them.
Now for the write up :D
Rear Setup
First off strip your fto trailing arms of the hubs, dust plates and caliper brackets to give you the bare arms, don't lose the 4 bolts with washers which hold the dust plate/caliper brackets on.
Next fit the Galant parking brake arrangement to your dust plates. Pic shows them already fitted but they aren't hard to fit. The two top bolt holes in the galant dust plate fit the fto arm but the other two need slotting. When I first got them I thought they lined up perfectly but turns out not :roll: . As you can see in the picture they need extending to meet where the fto arm holes sit.
(picture deleted by author)
Next bolt the dust plate to the arm to give you this
Put your wheel bearing back on and tighten the nut, apparently they are non reusable so you will need to source another
Next fit the evo brembo 5-9 discs.
All thats left is to pop the cover off your discs and adjust the handbrake shoes until they are nearly touching the discs.
on the back of the calipers there are 2 sets of lugs which the brake fluid line is located through, they have one at the top and one at the bottom and you can use whichever you like according to which caliper you have on which side (left and right sides will use opposite to each other obviously) the trouble is because the calipers are not designed for the fto rear trailing arms the bottom lugs on each side catch the arm so the caliper wont sit flush.
I just cut the lugs off as flush as i could with the back of the caliper
you need to make sure you fit the brake hoses before fitting the calipers or they wont go on, this is how tight it is:
The evo caliper bolts are slightly too long so i had to cut them down about 10mm to stop them catching the disc
Fitting the Calipers in place is near impossible this is done whilst everything is on the car as there is no way of getting a spanner or ratchet in there ! So i built this whole setup off of the car and got a mate to help hold it up whilst fitting it as its very heavy when all together !
In the last picture the caliper is on the wrong side, but i have changed this. Make sure that the bleeding nipple is at the top when fitting them otherwise when you bleed the calipers not all of the air comes out !"
Original Link: http://www.mirageforums.net/viewtopic.php?f=7&t=48370
Re: Rear Brembos
Yeah seen this suggested before and seen the post as well. Trouble is finding the Galant parts as we never got that model here in Aus. Still not a perfect system either but props for making it work.
vipfto
Re: Rear Brembos
Post by vipfto »
hj galant and magna same bj
Re: Rear Brembos
vipfto wrote:hj galant and magna same bj
Oh? The FWD ones? I know they can bolt them up fairly easily. Maybe should see if Magna hubs fit too haha
Re: Rear Brembos
Whole lot of extra weight for no reason if you ask me..
Re: Rear Brembos
Bennoz wrote:Whole lot of extra weight for no reason if you ask me..
As in the hubs or calipers? Just evening out the distribution. :lol:
vipfto
Re: Rear Brembos
Post by vipfto »
This^^^^
sh*t if wasnt for handbrake would prob ditch rears completly :lol:
But seriously putting in a drum system is heavy even with the lighter brembo caliper it wont offset the difference.
Plus i'm the poor bugger that will do it
Re: Rear Brembos
But the epeeeeeeen........
Re: Rear Brembos
Ah that combined handbrake/disc brake rear setup can eat a fat bag of dicks.
Re: Rear Brembos
What system does the FTO use then? Or rather, would there be a problem with just mounting the caliper but leaving the FTO hub stuff as it is?
Re: Rear Brembos
Can't, unless you don't want a handbrake.
The Brembos don't have an internal handbrake mechanism, hence you have to use the drum for handbrake, clamps on to the hub to apply handbrake.
Whereas with the stock brakes, the handbrake mechanism is in the caliper, it squeezes the brake pads to apply handbrake.
Re: Rear Brembos
Replace standard FTO rotor (something that is rarely done by anyone) with a good quality one, good quality EBC or similar pads, rebuild calipers, replace 20 year old (stretched) handbrake cable. That's all you'll ever need.
Re: Rear Brembos
Well that's slightly more complicated... Does the Evo use a drum setup then?
Vectose wrote:But the epeeeeeeen........
This but. :( :lol:
vipfto
Re: Rear Brembos
Post by vipfto »
Yip
Re: Rear Brembos
Bugger. :lol:
Re: Rear Brembos
Yeah that's all I did. RDA slotted/dimpled rotors and EBC reds. Both from group buy. My handbrake cable is fine.
vipfto
Re: Rear Brembos
Post by vipfto »
This^^
Re: Rear Brembos
Just get some Brembo stickers. Will snap your neck when you hit the brakes.
