brake pad scraping on brake disc
- JacksonChater
the back braking pad appears to be rubbing on the brake disc. any way to free it up and stop the scraping noise? halp
Re: brake pad scraping on brake disc
Means you're out of pads. Change the pads.
- JacksonChater
is that a DIY fix or would it be easier to just send it to the mechanics?
- Shhtuart
If you've never worked on a car before then send it to a mechanic. The rears are more difficult than the fronts.
