Lost power
- payaya
Re: Lost power
Yes
- Supplanter
Re: Lost power
Took it to the mechanic, it is probably a dead cat convertor that is causing the problem, won't know if it is the root cause of the power loss until I get it changed, though. Also need new front struts, strut tops and front sway bar D bushes.
Bushes are SPF1344-16k (do I need 2 or 4?)
Tops are 2 x SM6756
Struts are KYB 334155 and 334154
Tops are 2 x SM6756
Re: Lost power
spf1344-16k come as a set of two which is all you needSupplanter wrote:Took it to the mechanic, it is probably a dead cat convertor that is causing the problem, won't know if it is the root cause of the power loss until I get it changed, though. Also need new front struts, strut tops and front sway bar D bushes.
Tops are 2 x SM6756
Re: Lost power
Lol sahin the bush expert
- Supplanter
- -Nighthawk-
Re: Lost power
What was the issue?
- Supplanter
Re: Lost power
Dead cat.-Nighthawk- wrote:What was the issue?
Dead cat.
Dead cat.
Re: Lost power
Eh, just remove the cat :p
Re: Lost power
Dead cat three times!
- bjk
- Totes
Re: Lost power
But was there enough room to swing one?Supplanter wrote:Dead cat.-Nighthawk- wrote:What was the issue?
Dead cat.
Dead cat.
Re: Lost power
It's an FTO, how could there be?bjk wrote:But was there enough room to swing one?Supplanter wrote:Dead cat.-Nighthawk- wrote:What was the issue?
Dead cat.
Dead cat.
