Hi guys.
Aerial antenna pulley needed for 1998 GPVR. Motor is fine, just need the device that makes the aerial go up and down.
Cheers, Gaz
- GazGPvR
Re: Aerial antenna pulley needed for 1998 GPVR
Welcome to the club.
Aerial is the same for all models where it is fitted, so you dont need to ask for one for a GPvR. Ive found one in Japan for you as a worst case scenario. Have replied to your PM.
- GazGPvR
- payaya
That comes with the aerial. What is the measurements of the mast? May be able to match one up.
